Old 05-09-2018, 08:03 AM   #1
Glenn Briglio
Glenn Briglio's Avatar
Liked 973 Times in 310 Posts
Default 3" aluminum driveshaft
What company have you dealt with for a 3" aluminum driveshaft that you are happy with?
Old 05-09-2018, 11:07 AM   #2
Jim Caughlin
Liked 805 Times in 245 Posts
Default Re: 3" aluminum driveshaft
I have a 3" alum driveshaft that was built by Inland Empire, I cross the finishline at 9400 RPM and have relatively low HP. Interestingly, I was able to test duplicate steel (13#) and the alum one (10#) on back to back runs, zero performance difference. Actually, I can't say that I saw any noticeable performance improvement from any of the lightweight parts that I incorporated over the years (alum spool, lightened ring gear, gundrilled axles, etc), go figure...
One other note on going to a 3" alum driveshaft, don't forget about resonance / critical speed, it isn't purely a matter of strength. I believe there is a chart on the Mark Williams site that lists length vs RPM for different driveshafts.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 05-09-2018, 01:39 PM   #3
Race Clean
Liked 129 Times in 53 Posts
Jim Caughlin
SS 6019
I think that is the reason right there to use a Aluminum when you are allowed.
Race Clean is offline   Reply With Quote
Old 05-10-2018, 02:27 PM   #4
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
I put a M/W 3" aluminum in mine. Very happy with it.
Allan
55 Chevy is offline   Reply With Quote
Old 05-10-2018, 04:33 PM   #5
Glenn Briglio
Allan
M/W doesn't make a 3' aluminum shaft only 3.5
Old 05-10-2018, 04:47 PM   #6
jmcarter
jmcarter's Avatar
Liked 3,193 Times in 975 Posts
Another vote for M/W....only took them a few days from ordering my aluminum shaft to arrival; great technical support when ordering and absolutely no problems.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-10-2018, 11:11 PM   #7
55 Chevy
55 Chevy's Avatar
Your are absolutely right. It is a 3.5". Sorry my mistake.
And I just pulled it out last week!
Old 05-11-2018, 12:48 AM   #8
55 Chevy
55 Chevy's Avatar
Old 05-10-2018, 08:46 PM   #9
Jeff Stout
Liked 704 Times in 281 Posts
Jim Caughlin
SS 6019
^^^ This. I found nothing in a BBC running high 9s bottom 10s and changed all the same things
