Old 03-27-2018, 08:01 PM   #1
flash
Liked 6 Times in 5 Posts
Default throttle stop motor on dyno question
anybody dyno there supergas motors with stop on motor-wide open of course? then take the stop off to see the horsepower loss incurred by having that restriction on the motor.
flash is offline   Reply With Quote
Old 03-27-2018, 10:58 PM   #2
SC363B
Default Re: throttle stop motor on dyno question
Never on dyno but I always took my under the carb TS off to run Q16 with my SC dragster It would run 3-4 hundredths quicker.
SC363B is offline   Reply With Quote
Old 03-28-2018, 06:04 PM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 552 Times in 215 Posts
My friend did.....and on Q-15 which is a 50-50 mix of Q-16 and a std fuel that I don't recall what fuel that is.....
His 582 with a Sunset Plate stop (tapered bottom) vs no stop was about 20-30 hp difference....IIRC....over 1000HP with and without the plate...
I borrowed his stop and won a race with it and also ran Q-15 for a while myself....
Rich Biebel
S/C 1479
Stock 147R
Old 03-28-2018, 09:03 PM   #4
Hacksaw
Liked 312 Times in 175 Posts
VP C-15 is a 50/50 mix of C-16 and C-14. Q-16 is an oxygenated fuel.
Old 03-29-2018, 03:08 PM   #5
Rich Biebel
Q-15 is a mix Gary Stinett supposedly tried and is what I was referring to.
A 50/50 mix of Q-16 and a non oxygenated fuel. I just don't recall what that fuel was.....C-14 or C-16 ...or ?
My buddy ran it for a few seasons and won numerous races with it.
His carb was calibrated for it.....and dyno'ed with it.
I ran it for a while and just upped my jets a few sizes.
It ran fine and is worth a solid 2 MPH...
Our friend and VP dealer supplied it to us at the races....
Very offensive fumes and I was more than happy to stop using it.....
You definitely know when your handling "funny gas" as someone once called it...
Rich Biebel
S/C 1479
Stock 147R
Old 03-30-2018, 09:21 AM   #6
shawnfricke
Q16 + C15 = Q15
I used it and we still run it in one car, works well as long as you're tuned up properly.
Shawn
shawnfricke is offline   Reply With Quote
Old 06-01-2018, 03:44 PM   #7
B1Ken
What about a disc stop? I can't see any reason for a HP loss with that. It basically acts like a four hole spacer.
B1Ken is offline   Reply With Quote
