Liked 166 Times in 71 Posts
Gm A body stocker, what is the hot ticket? Moroso seem to be going dead fast.
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
Liked 1,922 Times in 432 Posts
The Moroso springs will die early unless you have really good shocks.
If you're running a big block, try the small block with air springs from Moog or TRW.
Alan Roehrich 212A G/S |
Liked 2,343 Times in 465 Posts
I believe most of you wear out your suspension traveling to and from the track and not on the track. Once I get my springs set to where I want them I would jack up and block the car then tie it done against the blocks and not against the springs in the trailer. Why would you want to tie your car down tight against the springs then let it bounce around on the way to the track. Try it your like it. BP
Call Marty Rinehart at Rinehart Performance.
