Liked 708 Times in 285 Posts
Looking for part number for the valve that screws onto collector and house from valve cover slips on. NAPA says $50.00 each and I walked out. Thanks in advance for part number or year and make of vehicle.
Liked 12 Times in 1 Post
Standard Motor Products AV7
Liked 2 Times in 1 Post
RT - SS/X circa 1972. ![]() Talbot Racing Family |
Liked 335 Times in 182 Posts
u need a Dorman 355050 --- its called a secondary air injection check valve about $12-15 - most auto parts stores--go to a late model junk yard look for most any 92-2007 or so GM car they go and are part of the plumbing for the pollution stuff should be by the exhaust manifold-- remember that GM used the type the had Hose barbs on both ends an the type that had a hose barb on one end and a female threaded port on the other end ---FED 387
Liked 9 Times in 6 Posts
Autozone cv8 By BWD
Liked 930 Times in 264 Posts
NAPA is a Echlin CRB 229000 $16-18.
Liked 8,223 Times in 1,538 Posts
Jeff, I know you have multiple race cars ...you do realize you can not run a vac u pan system in stock eliminator .?
Liked 1,987 Times in 599 Posts
I don't use them on my car. Just connect the hose right to the pipe stub on the collector
Mike Pearson 2485 SS |
