Liked 294 Times in 93 Posts
Weld AlumaStar 2.0 ftont runner 4.5bc
Weld AlumaStar 2.0 15x10, 4 3/4bc(GM), 5"bs used 9x30 Goodyear radials Weld Drag Stars front runners 2 sets Weld Drag Stars 15x10, 4 1/2bc(Ford/Mopar), 5"bs Afco 3850sp shocks installed but never run adjustable collar ride height set up used M/T 29x4.5 front runners REF FE headers 66/67 Fairlane/Comet 4-1's and Tri-Y's coated nice JPT C4's 2.75 and 2.92 transmissions ATI Converter 5800-6000 in my Stocker "N" case R/E 4.86 35 spline steel spool 4.63-5.29 R&P's Strange Aluminum center section empty Strange Aluminum R/E 5.00 35 spline Strange Aluminum spool Moser axles 35 spline rifle drilled profile milled flange stock Mustang/Fairlane length 5/8th studs Yukon "N" case 35 spline Strange aluminum spool 4.63 390-428-427 cranks 2 427 Ford blocks Crower 6.480 Ford journal size fresh new Crower bolts and sized Ford PI Aluminum Intake 390 Stocker motor complete(Edelbrock by Kuntz, T&D rocker, Trend, etc) may seperate Extra C6AE-R cast iron heads complete fresh by Kuntz Schubeck solid lifter dyno time only .875 Ford Canton 2 quart accumulator Aerospace front and rear brake setup Turbo Action Cheetah C4 rev pattern shifter plus alot more 21zero-3seven3-four 0 zero 4 Thanks RJ |
Sent you a text
Liked 4,389 Times in 505 Posts
Hi RJ. I am interested in the strange alum 9in case. What bearing size is it? Is it the lightweight case? Price? Also what are you asking for the transmissions? Don't need the bellhousings as we run small blocks. Thanks.
Liked 692 Times in 205 Posts
Pm sent
Liked 13 Times in 7 Posts
PM sent regarding 390 and spare heads
N/A |
