Old 12-13-2017, 09:22 AM   #1
stock1080
Liked 94 Times in 38 Posts
Default Hydraulic Thow out bearing
Are there any stocker or super stocker stick cars using a hydraulic bearing? I have a jerico 4 speed.
stock1080 is offline   Reply With Quote
Old 12-13-2017, 12:43 PM   #2
Nmbr1GMfan
Default Re: Hydraulic Thow out bearing
Never used one in S/SS but I have used the McLeod one in a street car with a Liberty's T56 and it worked beautifully.
Todd Greene
Old 12-13-2017, 01:41 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
You may want to look at the rule book, as I am pretty sure it states no hydraulic or electric. Most convert to linkage as it's easier to get the air gap set correctly and for consistency and another place to adjust for RT. The electric statement prevents stick racers from using a magnet for releasing the clutch pedal in both stock and SS.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-13-2017, 04:05 PM   #4
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Sean
The 2017 rule book only speaks to air or hydraulic shifters and not clutch linkage...
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
Old 12-14-2017, 08:52 AM   #5
stock1080
thank you, I have a 85 z28 that came with a hydraulic unit. I do have a manual linkage now. I was thinking in a 99 Camaro you would have to have a z-bar made. If any gen 4 stick shift guys could let me know who made it for them. thanks, jeff
Old 12-14-2017, 10:54 AM   #6
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Tom Russell @ Russell Performance has probably made z-bar style clutch linkage.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 01-05-2018, 04:18 PM   #7
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Sean
I am building one that is both hyd. and mechanical.
A mechanical t.o. bearing and fork pushed by a hyd. slave cylinder.
I wonder if this is legal ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 01-05-2018, 05:17 PM   #8
Maverick
Liked 36 Times in 26 Posts
I am interested in what your are doing with the hydraulic cylinder, in whether it will be quick enough, and how big a cylinder, and how big the bore on the master cylinder. I run a hydraulic throw out bearing, that uses no fork. I don't run stock or super stock, but it is legal in my class. I don't see many hydraulic systems, except on the new cars. Very controversial. And what type of fluid you plan on using. I don't believe I would call this a hydraulic throw out bearing, I would call it a clutch hydraulic slave cylinder. Hydraulic bearing won't have a fork
Old 01-06-2018, 11:43 AM   #9
Sean Marconette
Alan,
I would check with your division tech director and get clarification from them on legality. There are a few reasons why you would not want to run a hydraulic setup even if it's not a class car.
Do you want to go rounds and consistently cut a light? It's hard enough with a mechanical setup to cut a light constantly, then add the reaction rate of the fluid and those components. Depending on the ambient temperature, the viscosity is going to add another factor on your reaction.
Either way, good luck.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-06-2018, 10:13 PM   #10
DonatoEng
Liked 8 Times in 5 Posts
Its the 009 car that a friend purchased that I'm going to run.
I used an hydraulic system with a fork in my stocker Dakota since I built it in 95. NHRA had no issue as it was the production set up. They did look it over for and solenoid in the system.
John
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
