I have light brakes on a heavy spindle (76 nova) is there a drum spindle I can use with these brakes that will shed some weight?
Todd Greene |
Liked 5 Times in 4 Posts
NHRA only allowed aftermarket brakes for safety purposes! Your Nova only came with factory front disc brakes and you are only allowed to use the stock spindles to be legal!
Thank you!
Todd Greene |
Liked 237 Times in 126 Posts
The NHRA allowed part is a bit deceiving. This is what the 2017 book says for Stock:
BRAKES Must be equipped with stock production four-wheel hydraulic brake system, or aftermarket disc brakes meeting the following criteria: 1. Minimum effective piston area per wheel: 3 1/2 square inches. 2. Minimum disc (rotor) diameter 10 1/4 inches x 5/16-inch thick. 3. Must install dual master cylinder with any modified brake system, splitting front and rear into separate systems. 4. Dual calipers on rear wheels permitted, maximum one hydraulic brake line to dual rear brake system (no wires). 5. Rear wheel line-loc prohibited; front wheel line-loc permitted. Parking brake optional. 6. Carbon-fiber brake rotors prohibited. See General Regulations 3:1. As far as spindles go. Stock.
Liked 239 Times in 114 Posts
Couldn't you buy a brake package that included the spindles ? Those spindles might not have that extra metal on them . I know of some aftermarket brakes need the spindles sent in for them to be modified .
Hmmm.
Todd Greene |
