Liked 7 Times in 5 Posts
3000 lb car /350 flat top pistons for brackets and some S/SS . Solid roller 630 lift, 276 / 284 @ 50 ,107 CL , is this too much cam or is it a parts breaker ?
Liked 986 Times in 314 Posts
Liked 2,023 Times in 607 Posts
If its an automatic it would probably like a 105 Lobe center. What rocker arms are you using?
Mike Pearson 2485 SS |
yes it's auto. , not sure on the rockers , its a used cam , I'm trying to. convert my crate motor to a mild GT/SS , got some heads and a q jet. Only ever had stocker cams so I'm not up on what I should use , all I have to do is cut the index , not looking to set the record . thanks
That cam will get you to the index. If you have some decent heads and carb
