Liked 7 Times in 5 Posts
Is a 3/8 line from pump to Qjet big enough , if so what size should the return line be ?
Liked 602 Times in 165 Posts
I ran -12an from the tank to the pump and -10 an from pump to regulator then -8 an to the carb, -10 an return from the pump to the tank for my qjet
Liked 364 Times in 138 Posts
IMO Mike, 3/8" is too small to feed one of your fuel hungry SBC's.
![]() I was going to suggest -10AN to the regulator, -8 to the carb and -8 return.
Dave Turner SS/GT #1153 |
Liked 53 Times in 38 Posts
I do....Aeromotive A1000
Dave I checked your engine specs and understand why you need that much fuel! I got 390/410 lift 1.94/1.50 valves with a Qjet, and run the same class as you. I was told it cost 2-3 times as much to run a Ford .WOW. I priced the a1000, $550 cdn with tax another WOW. I just retired and we are on a budget ha ha .See you next year, and thanks for the input . Mike
