Old 11-20-2017, 06:26 PM   #1
BA1927
BA1927's Avatar
Liked 26 Times in 10 Posts
Default Mopar - Dana 60 Housing-Posi-Gears - 8 1/4 gear set ++++
DANA 60 - HOUSING (47 7/8" FLANGE TO FLANGE) 4:10 RING & PINION - CHROME REAR COVER - 2.87 MOPAR AXLE BEARING - 35 SPLINE POSI UNIT - WILWOOD DISC BRAKES - ALSTON LADDER BAR BRACKET ARE ON THE TUBES - $1200 obro
(1) NEW MOROSO 89552 0-15 LB 4" TIRE PRESSURE GAUGE NIB - $120 OBO
(4) (TAKE OFF)M/T RADIAL STOCKER SLICK'S --- both set 30x9x15
(2)(TAKE OFF) M/T FRONT RUNNERS 29x4.5x15 GREAT TREAD LEFT $160
(1) 8 1/4" MOPAR REAR 4:56 GEAR SET GEARS AND INSTAL. KIT $250 --
(1) MOPAR 1993 DODGE DAKOTA V8 AC DELEATE BRACKET AND MOUNTING HARDWARE -- $50
(1) MOPAR 1993 DODGE DAKOTA ALTERNATOR IN GOOD SHAPE
(1) MOROSO S B CHRYSLER ALTERNATOR MOUNT NEW (MINUS TURNBUCKLE) WORKS WITH NIPP 93mm-115mm --- $100
(2) NEW SS MERGE COLLECTORS 1 5/8" -- MAKE A REASONABLE OFFER
ba1927@aol.com or 508-269-9611 Located in Massachusetts
BA1927 is offline   Reply With Quote
Old 11-25-2017, 08:29 PM   #2
BA1927
BA1927's Avatar
Default Re: Mopar - Dana 60 Housing-Posi-Gears - 8 1/4 gear set ++++
Found 1 of the Strange Axles in our storage stall today for the Dana
