Liked 28 Times in 15 Posts
I noticed the rubber bushing in my top strut mount( camber plate? ) is cracked and falling apart. My search at the junkyard turned up 8 that were in worse shape than mine. Found some in the shed that are in good shape but brings up the question, is an aftermarket piece available or is there a way to eliminate the rubber altogether? Junkyard parts are getting harder to find for these cars. I use an old set of Koni struts up front. Thanks in advance guys.
Liked 99 Times in 60 Posts
One option, the factory replacement upper mounts are still available. Check your local parts store for Moog or other brands.
Larry Woodfin 471W |
Liked 1,034 Times in 368 Posts
If you go with OEM, I believe the Z-28's and IROC's had a bearing, where the cheaper models had a bushing ...
Jeff Niceswanger 3740 SS |
Jeff, will check that out. I don't remember seeing that before but will check, have access to many examples. The ones I dug out of the shed have bushings. Will price new pieces also. Nice Kit shown there, maybe in the spring time.
Liked 333 Times in 180 Posts
look on eBay top strut mount plates lots of the with the bearing no bushing about $55-75 per pair---Fed 387
The quick fix now has been a set of junkyard pieces with bearings I found. The issue was glass beading them and having trouble getting that stuff out. But it it did work. Will look at aftermarket parts this spring.
