Old 11-04-2017, 10:37 AM   #1
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Default 426 Hemi Display Engine
I need some help with a project I am currently putting together. A close friend wants me to build a 426 Hemi Display engine for his car collection. I am looking for the following engine parts:
I need a 426 Hemi Block. This Block can be destroyed internally, as it will never run again. No pistons, rods or any internal part will be installed.
I need a crank shaft. I’m told a 440 crank will work?
I would like to find an old cross ram intake manifold which can be fitted with new carbs. That’s about the only thing on this Display engine that will be functional.
I have tentatively located a set of crashed heads from a SS/AH racer. Again, no one will ever look at the technology of another racer. This I promise!
I need Stock type valve covers. Spark plug tubes.
I have a stock oil pan, timing cover, oil pump and water pump.
Any help on the above listed parts will be appreciated. I’m not trying to get these parts for nothing.
John Duzac
504-259-5935
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 11-04-2017, 11:18 AM   #2
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
Default Re: 426 Hemi Display Engine
John Duzac
504-259-5935
Bob Lambeck has older hemi parts his # is 208-250-8005
Old 11-04-2017, 12:10 PM   #3
Albert Lee
Liked 258 Times in 49 Posts
Long ago I planned the same thing but have since abandoned the project. I have a block, crank, piston, rods, and heads. All cheap! Will separate.
Al Corda 612.963.4540 text/cell - NO pm's please
Albert Lee is offline   Reply With Quote
Old 11-04-2017, 05:24 PM   #4
Julie Jordan
Liked 591 Times in 102 Posts
John Duzac
504-259-5935
We have some old parts. Contact Jared @ 209-765-9718.
Julie Jordan 7549 STK
Julie Jordan is offline   Reply With Quote
Old 11-04-2017, 07:06 PM   #5
John Duzac
John Duzac's Avatar
Julie, thanks for your reply. I have received many calls about the Hemi Parts. I will call Monday.
Old 11-04-2017, 10:36 PM   #6
Spyphish
Liked 679 Times in 180 Posts
Unfortunately I have you a set of heads. Deck height classified so good luck and mum is the word. Valdez
Old 11-05-2017, 09:06 AM   #7
John Duzac
John Duzac's Avatar
Yes Spyphish, mum has always been the word. I need some parts as discussed. I have had a lot of responce from guys that have damaged parts. This Display engine will never run and only for people to view. No one will look at the parts, so racer’s technology will be protected. This is a promise! Besides that, who would know where the parts came from. It’s on a need to know basis and no one needs to know.
I will call you next week.
Thanks...
Old 11-04-2017, 10:37 PM   #8
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Call Dave Collette @ 443-807-1569, he has alot if stuff.
Bob Bender 144 O/SA
