Old 10-03-2017, 02:19 PM   #1
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
Default clutch and trans info
Putting a stick in my Drag Pak this winter, who has the best clutch setup? Best transmission? Looking at G-Force for the transmission, any thoughts on this?
Dennis Breeden
FSS/K
denbreeden is offline   Reply With Quote
Old 10-03-2017, 07:39 PM   #2
Liked 1,893 Times in 423 Posts
Default Re: clutch and trans info
If you want something affordable, reliable, consistent, and easy to work with, a Jerico DR4.4, a McLeod SoftLock, and a QuickTime bellhousing. Might not be the absolute fastest. But it will go rounds, and won't cost you your life savings.
Old 10-03-2017, 07:44 PM   #3
denbreeden
denbreeden's Avatar
Thanks Alan, I appreciate the advice. I really don't want something I have to constantly repair. Going to be a challenge I'm sure.
Old 10-03-2017, 08:08 PM   #4
Nmbr1GMfan
Great advice. Call Cale Aronson at Black Magic Clutches, he can help you with a clutch setup and data. He also has clutch tuning seminars.
Todd Greene
Old 10-03-2017, 09:22 PM   #5
Rod Greene
Liked 242 Times in 81 Posts
Thumbs up Re: clutch and trans info
Rob Youngblood at Advanced Clutches 208-880-6214 nobody better. Great personal service always there to help and answer questions and make your car quicker. Don't believe me ask Bob Gullet.
P.S. you might be surprised at how easy it is to run a clutch car.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 10-03-2017, 09:48 PM   #6
james schaechter
I love the Jerico', but I think the G101 is worth a look as well. It has bearing supports between third and fourth and is strong. The soft locks are good for basic ops. I would say most single ten inch have a big tuning window. I prefer a dual 7 Youngblood. Easy to tune and you can tighten it up so it doesn't wear a lot.
The two things that get newbies in trouble.
1) not having enough clearance between the fingers and the throwout bearing
2) the burnout
Make sure you work out hand signals with a crew person in case you need to abort thre burnout. Make sure the tires have some water on them. Get the rpm up enough to snap the tires loose in the water.
Don't ever shift in the water unless you race a true clutchless trans. i,e. Liberty Equalizer or GF2000 etc.
It is more fun than you can believe! Good Luck!
James Schaechter 3163 STK
Old 10-03-2017, 11:33 PM   #7
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
I have seen more racers have problems with Jerico's this year and also having issues with the new ownership getting parts. The G Force might be a better way to go.
Dyno is online now   Reply With Quote
Old 10-04-2017, 11:24 AM   #8
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Dennis Breeden
FSS/K
Call Cale Aronson at BlackMagicClutches for the clutch. I just got my nex gen from him it's a work of art. Awesome piece. Super nice guy and will go above and beyond to help you.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 10-04-2017, 11:54 AM   #9
denbreeden
denbreeden's Avatar
Thanks for all the replies, I appreciate everyone's input. It will be an interesting change I'm sure.
Dennis Breeden
Old 10-04-2017, 01:23 PM   #10
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Call G-Force and ask about their trade-ins, it will save you some money if they have something in stock. You will then get an updated trans with your gear choices at a reduced cost. Also as suggested get an input shaft sensor installed. How long the clutch slips is the biggest item to log and track. Browell and a window to adjust the clutch, Browell has a conical bellhousing similar to a QT but is custom and maybe a couple hundred more than a QT. You can also have the window clocked where you want it. Several fast cars are using Cale's clutch and like his stuff, several others including myself have Robs dual disc clutch. I have had good luck with Rob and the clutch has a wide tuning window. There are still a lot of Mcleod and Ram clutches in use to. In my opinion having a data logger is key to knowing what the cluch is doing, regardless of who's clutch is in the bellhousing.
Good luck
Sean
Sean Marconette
84 Mustang
5060 SS/N
