I used nitrogen in the slicks this past weekend for the first time, and noticed took more effort to bring smoke off the tires in the box, is this characteristic of N in the tires? Anyone have similar experience? Otherwise worked really well, much more manageble in the heat! Joe Helms
#2 | |
Liked 43 Times in 29 Posts
Mark Ruset 2048 STK |
Mark, I had heard similar comments, thought I would try anyway. On bias10.5/30s, track temp 130f and tires 180f had no problem with traction or consistency, in bracket setup. Main advantage was much easier heat management! Sidewalls show a little discoloration, though.. Joe.
Bringing this post to life again. Anybody have any thoughts on using nitrogen in a stocker. Is it worth the investment, since you check them everytime before you run anyway? Does it give any ET advantage?
Jeff Interlicchia 7077 D/SA 1998 Pontiac Firebird LT1 J707 E/T 1966 Dodge Coronet 500 |
Liked 8 Times in 7 Posts
i want to know if there's that much difference between 80% N and 95% N....and if there's that much difference, can you PROVE it?
helium makes better sense to me cuz 80% nitrogen is whats already in the air.... |
Liked 359 Times in 103 Posts
First, I am not for it or against it but it is the make up of the air we breathe is the big difference.
Its the moisture in the air that makes the pressure go up and down radically with heat or cooling in the tires. With nitrogen there is almost no moisture as to bottle the Nitrogen it has been cooled to liquid which requires cooling it to if I remember correctly about -190 degrees C therefore there is basically no moisture in it. Bottled nitrogen is made from air because there is so much in the air we breathe. Helium is much more expensive and much lighter which would make it less stable with temp changes. It also leaks out much easier. Just My 2 Cents Last edited by 63corvette; 04-12-2010 at 02:23 PM. |
#7 | |
If youve ever breathed helium ox mix in mixed gas diving....well itll litteraly suck the heat out of you from your lungs......unless its warmed, and youre in a hot water suit great way to go hypothermic in about 20 minutes flat.
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
oops, i forgot the "
Liked 138 Times in 51 Posts
Isn't one of the advantages of nitrogen that the molecules are bigger and less prone to "seep" out through porous rubber? - Slicks as well as street tires.
If it does keep tires cooler, it sounds like a good idea for trailer tires! |
Liked 60 Times in 12 Posts
QOUTE-If it does keep tires cooler, it sounds like a good idea for trailer tires! QUOTE
That doesnt sound like a bad idea.
2894 STK |
