Liked 325 Times in 50 Posts
Several DP motors, 6.1, 5.7 most new never started, couple with dyno time only, a DP short block or two, a couple T350 Pro Trans. One never run and one with time. Pick your ratios. Both elec shift, reverse pattern, clean neutral. best stuff you can buy, 6.4 crank and pistons, new (convert 6.1 to 6.4) ask if you don't see it, DP stuff mostly. Maybe a 350 converter, maybe some more.
Jeff Teuton 4022 STK |
Liked 15 Times in 6 Posts
Jeff,
What are you looking to get for the T350 protrans? What converter might you have for the T350? Thanks, Bill |
Liked 54 Times in 24 Posts
Jeff,
Sent you a PM.
Todd Gross 3323 FS/E,F |
