I am attempting to build my own Thermo-quad for 72-73 340. I don't want anything on it I don't need
but, leave or modify everything I do. Is anybody willing to share any tips on successful modifications? Fuel pressure? Is the vacuum diaphragm on right rear necessary to regulating air door? Is converting to Holley jets and removing the metering rods from primary circuit the best? Is removing the choke S/S legal? Is a -6 inlet adequate for fuel delivery at say 530 HP? I've read about 40-50 HP differences in modified Thermo-quads so, there must be some things that work better than others. Thanks |
Liked 288 Times in 109 Posts
Liked 4 Times in 3 Posts
I run 74 duster in ss/ja 360cid here in finland,.I have problem all the time with accelerate pump seal ring i have use blue and orange rubber,.When it gets race fuel it goes fat and after that wont work at all,.same times cant get engine runnin before I take the thermoguad at pieces and change the rubber,.here in europe we run unleaded racing vp fuel could this be the problem..thanks
Liked 4 Times in 4 Posts
Contact Jim Wahl, he's very good with these carbs. He's a member here.
Jim Rountree |
Liked 11,032 Times in 2,267 Posts
Van Lant
Anyone have a sorce for thermoquad secondary jets
#7 | |
Jim .
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 239 Times in 114 Posts
You can buy the good accelerator pump seals from Ninja Fuel Systems on eBay . Compatible with ethanol laced fuel .
Holley Jets make it a lot easier to tune because readily available.
No metering rods make it a lot quicker to disassemble and assemble as they are a pain. Choke must remain in Carb. -6 works fine...Big float bowl capacity Diaphragm not vital but helpful in controlling Air Door. My opinions.......Your results may vary.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 03-04-2017 at 11:43 PM. |
Do you have holly jets in the secondarys, or only in the primarys
