Old 01-28-2017, 10:18 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Gapless Rings
What are your thoughts on these? Do they have pros and cons? Also I think there is a choice between a gapless top ring or gapless second ring, any benefit there?
'65 Mustang SS/L & L/SA
Old 01-28-2017, 10:34 AM   #2
carl hinkson
Liked 18 Times in 10 Posts
Default Re: Gapless Rings
Gapless top ring is a good deal..
The second I would not use as there is not place for the gases to go if its a sealed, Once you get pressure between the first and second ring to top is lifted by the pressure between the 2 rings.
Thats why most pistons have a groove between the first and second groove, Its called pressure seal groove or an accumulator goove. to give a place for pressure to build up so it will not affect the seal of the top ring.
carl hinkson is offline   Reply With Quote
Old 01-28-2017, 11:28 AM   #3
Liked 1,912 Times in 429 Posts
The gapless top ring is fine. Call Keith Jones at Total Seal and get his recommendation for your specific combination.
I do not use a gapless second ring, as it prevents any gasses that get by the top ring from escaping, that unseats the top ring from the bottom of the top land, causing it to flutter and leak. What little does get by will help the oil ring seal, and won't hurt anything. If the top ring is allowing much of anything to get past, the second ring won't help, even if it is gapless. The function of the second ring is to pull a vacuum on the cylinder, and remove any excess oil that the oil ring doesn't get.
Old 01-28-2017, 11:36 AM   #4
randy wilson
Liked 22 Times in 22 Posts
I agree with all the above. And I've actually gained HP on the dyno, and ET on the track with a gapless top.
don,t have one
Old 01-29-2017, 01:04 PM   #5
Rick Leininger Jr.
Depending on piston speed, a gapless top ring can be a benefit, or become a detriment.
Rick Leininger Jr. is offline   Reply With Quote
Old 01-30-2017, 09:20 AM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
I tried the gapless top ring and my results were not good. I went back to the standard .043 top ring.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
