Old 01-25-2017, 10:04 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default Never seen a K&N oil filter endorsement
I don't think I have ever seen a K&N racing oil filter endorsement on this website at any time.......are they good or bad or what is the opinion ????
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 01-25-2017, 10:31 AM   #2
tj310
Default Re: Never seen a K&N oil filter endorsement
I tried them because of the hex on the end to ease removal for inspection of the Moroso pre screen . Not impressed...Trevor
Old 01-25-2017, 01:26 PM   #3
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I have used many of them, cut them open to inspect after use and have been happy with the K&N filter. Seem to be well built.
Old 01-25-2017, 01:43 PM   #4
FED 387
Liked 334 Times in 181 Posts
They used to be made in Albion Illinois by champion mfg now made in China and Mexico by other companies to k&in specs Mott as good as the previous filters lest costly more profit for K&N. less filtering unable to prefill the filter nuts may leak and on and on. Fed 387
Old 01-25-2017, 04:13 PM   #5
west coast
Liked 228 Times in 75 Posts
I quit using them when i could not prefill. Called them and said they resigned them. I like my oil instantly after an oil change. Before that I never had a problem with them.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 01-25-2017, 05:33 PM   #6
Ed Wright
Ed Wright's Avatar
Really hard to beat Wix & NAPA oil filters (made by Wix, last I heard)
Ed Wright 4156 SS/JA
Old 01-25-2017, 05:41 PM   #7
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Cost me an engine (and almost a second one) last year. Switched back to Wix and the oil pressure came right back. Also, I found the "hex" to be one step up from useless.
Paul Merolla is offline   Reply With Quote
Old 01-26-2017, 09:46 PM   #8
raisenracing
Have used K&N oil and air filters for years. No blowouts, seal problems and easy to remove. Also inexpensive for a quality filter and I usually cut the filter open after a couple weekends to be safe. Run them in both cars
raisenracing is offline   Reply With Quote
Old 01-27-2017, 10:55 PM   #9
Dale Hulquist
Liked 351 Times in 76 Posts
West coast, what are you referring to when you mention not being able to pre fill the K&N oil filter, I fill the filters I have before I put them on, do they make more than one type race filter ?
Dale Hulquist is offline   Reply With Quote
Old 01-27-2017, 11:23 PM   #10
west coast
The filter I had been using was redesigned to were you could not pour oil in it and be full before you screw it on the motor.I will have to look up the filter # maybe there is another K&N filter I could use. Will get back to this later this weekend after some research.
