Old 11-03-2016, 05:50 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Decking block
is it legal to zero deck a lt1 350 for stock eliminator? If not how much in the hole do I need to leave the piston.
Kdw1403 is offline   Reply With Quote
Old 11-04-2016, 04:59 AM   #2
richie 2
Liked 205 Times in 93 Posts
Default Re: Decking block
I doubt it...nhra/ihra have that spec. & required head gasket thickness listed...
Old 11-04-2016, 07:42 AM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Total deck with gasket IIRC is .062"
If you had a zero deck you'd need a .062" thick gasket....
That's for a late model EFI LT-1...
The old LT-1's probably have a total deck number that would not be safe to run.....
Rich Biebel
S/C 1479
Stock 147R
Old 11-04-2016, 07:54 AM   #4
Billy Nees
Liked 7,909 Times in 1,754 Posts
And with the way that a head gasket usually overhangs the bore, the hot lick is to use the thinnest head gasket that you can and more negative deck.
Billy Nees 1188 STK, SS
Old 11-04-2016, 10:38 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Really??
Old 11-04-2016, 12:03 PM   #6
Billy Nees
I guess THAT didn't come out right.
And the way the head gasket usually IS LARGER THAN THE BORE IN DIAMETER, ETC.ETC.ETC.
Old 11-04-2016, 01:21 PM   #7
Rich Biebel
Yes that's better Billy....
Rich Biebel
S/C 1479
Stock 147R
Old 11-07-2016, 11:37 AM   #8
randy wilson
Liked 22 Times in 22 Posts
I know that sounds like it's right, but for some reason if I run zero deck, the motor is a few horse better then when running the piston down in the block to get the same compression. Maybe it's just me.
don,t have one
