Liked 56 Times in 31 Posts
I am replacing the ignition wires on my SBC Stocker.
The cam has the #4 & #7 cylinders swapped. I was told to keep the #2 & #4 wires as far apart as possible and not cross them. What are others doing for routing their ignitions wires. It was suggested that I lay the #2 wire on top of the intake and run the 4, 6 & 8 wires along the other side of the valve cover. As this is going to be my only second season with this car, it is obvious that I have a lot to learn.
Thomas NHRA 1959 D/SA |
Liked 358 Times in 83 Posts
It will be interesting to see what others say on the matter, but I say that today's plug wires are so effectively insulated against arc-over and heat damage that the long-standing rule about never letting wires lay on each other is out of date. If you look at a number of Stockers and particularly, Super Stockers with front-drive distributors, you'll see lots of wires touching each other. OK boys, bring it!
I was of a similar opinion and was quite surprised when I was told this.
That is why I figured I would post the question here, as this is a very knowledgeable group on this site.
#4 | |
Liked 1,937 Times in 582 Posts
Mike Pearson 2485 SS |
Liked 24 Times in 13 Posts
Mike. Do you mean the sleeve at the plug end, so the headers don't touch the wires?
Terry K |
Liked 237 Times in 126 Posts
My SBF headers set my plug wire ends on fire so I put braided "fire proof" sleeves over them. About 10 inches long. I think that's what is being mentioned as sleeves.
Dale
#7 | |
http://www.jegs.com/images/photos/700/710/710-72013.jpg
#8 | |
