Recently rebuilt SBC. When priming the engine the drivers side rocker arms do get oil and the engine builds oil pressure. However all 8 passenger rockers are not oiling. There are no oil restrictors in the block.
The camshaft oil plugs at the back of the block have been backed off to ensure they are not restricting flow. When the rear passenger oil plug is completely removed plenty of oil does flow when the motor is primed. Does anyone have any ideas or experiences with this? Could the oil groove in the priming tool be misaligned? The oil priming tool is the type that simulates the distributor and has a oil groove at the bottom of the tool. Could the the oil priming tool not be properly aligned and thus the oil groove is too deep or high in the block? Thanks for your help in advance. |
Liked 285 Times in 87 Posts
Did you replace the plugs behind the cam sprocket? Where are you taking the pressure reading from? MB.
Liked 22 Times in 22 Posts
I experienced it once on a 355 Wissota B Mod motor. I primed it and primed it. Finally gave up, poured STP over the rockers, and told him to run it. Oiled fine. Must have been the priming tool. Don't know if that's your deal, but worked for me.
don,t have one |
#4 | |
I have not replaced the plugs behind the cam timing belt gear. Pressure readings are being taken at the oil pressure port at the top of the block next to the distributor. |
Liked 19 Times in 8 Posts
Some of he Prime tools will not align with the oil holes causing a bleed off just take a measurement
Joe Schweigert 751 SS |
Liked 93 Times in 52 Posts
Rotate the engine/crankshaft while priming. Happened to us a couple times.
Also what Joe said...if the prime tool's shaft is not "blocking" the correct oil passages, it wont prime that side. You will be fine when you drop the distributor in. Clark |
Liked 313 Times in 106 Posts
You can take rear oil galley plug out and see if priming tool is lined up with oil galley,I say it is out of line or doesn't fit the hole tight enough and is leaking out there.
Mike Taylor 3601 |
I wanted to provide an update. The oil priming tool height needed to be adjusted in the block. Both sides are now oiling.
Thanks everyone for your advice. |
