327/ 275 Chevy Engine
Engine Builder Tom Boucher COMPLETE ENGINE CARB TO PAN Fully race prepared block .060 over. Block Filled Interior surfaces Glyptal coated C10CP Carrillo .060 Pistons Custom Gapless Total Seal Rings Manley Rods GM Forged Crank Bullet Cam 4/7 Swap Schubeck Hyd. Lifters Fully race prepared 041X Heads Manley Valves 3/8 Push rods Bullet springs Guide Plates Comp Cams Ultra Pro Magnum XD Roller Rockers Melling Oil pump Chevy II Milodon Oil Pan w/ heater pad Aerospace elect Water Pump Tom Cassen 750 Quadrajet Asking $7500 Serious inquires only Call any time 508-942-2409 or PM me for any questions. *Have all records for engine builds. *Have Dyno sheets from last build
Don Fardie 1582 F/S B/G Last edited by Don Fardie; 03-20-2016 at 08:08 AM. |
Liked 6 Times in 3 Posts
What class did you run with this combo ?
F/S set the record back in 07-09...... 10.89
Don Fardie 1582 F/S B/G |
Liked 13 Times in 13 Posts
I hope this doesn't mean your not running stock any more ?
G. Walters/ F/SA |
Liked 452 Times in 134 Posts
How fresh is it ?
Thanks Jerry |
To answer your question... yes. I'm changing classes and going to be running some Nostalgia Class racing. Though I could run this motor, I much rather run a bigger cubic inch and build something that is not as restrictive as a Stocker motor. I’ll still be around, so you haven’t got rid of me yet!
Please note the motor also comes with an OEM in the box spare GM forge crank and 2 additional ready intakes.
Sorry I didn't see your post yesterday Jerry.......Since having the a new block and heads done I've put about 90 runs including Dyno time. Last time out last fall the car was running consistently high10.9's. .....there more there, but need more time to dial in the new clutch.
If it was completely refreshed I'd be asking more. Anybody who knows the car knows how I meticulous I am with my stuff and how well it is maintained. This is a good piece!
