Old 02-14-2016, 08:56 PM   #1
Rick Shirey
Default Inline Throttle Stop
Are many still using an in-line stop and being competitive?
Rick Shirey is offline   Reply With Quote
Old 02-15-2016, 03:32 PM   #2
63corvette
Liked 362 Times in 105 Posts
Default Re: Inline Throttle Stop
Not with a carb.
All the carb experts will tell you not to use a inline stop.
Just My 2 Cents
Rick Cates
63corvette is offline   Reply With Quote
Old 02-16-2016, 01:12 PM   #3
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I use one with mechanical injection. It works pretty well the vast majority of the time.
In 5 division races last year, I had two runs that were far from the target, like .07 fast and .08 slow. Both of these were time runs, but still not good because you don't know what the next run will look like. No data logger, but I wouldn't be surprised if it was a variance in throttle stop RPM.
S/ST 51
S/C 53
Old 02-16-2016, 01:34 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Still see an awful lot of good , repeating , dragsters using them.
The cable helps prevent the deflection you have with solid linkage.
I've done a few door cars with cable actuated inline stops that have worked quite well , But I would not use one with conventional solid linkage any more.
Old 02-16-2016, 02:14 PM   #5
sc583
Would you consider a Maxx Speed carb an inline stop?
sc583 is offline   Reply With Quote
Old 02-16-2016, 04:28 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
I use one on my S/C dragster.
Had a disc plate stop and the inline stop both on the car at the same time during part of 2014
Won a race using the plate stop.
Took it off and ran the inline just to see which might be better.
No real big difference....Just had to juggle stop timer numbers a little.....
Won another race that year with the inline stop.
I keep a very close eye on Stop RPM and everyone knows that's the big issue with Stop racing....
Would I prefer a Max Speed Carb.....absolutely.....but I'm not buying one. Just can't justify spending that kind of $$$ for a carb when I already have 2 good ones...
An inline needs the most rigid mount you can make.
I used an inline with Ron's injection and won with that too....and did NOT go back to an idle with that car/engine/system. A similar setup on a newer car refused to work though.....
I use the inline stop as a starting line enhancer when I bracket race....Takes 5 minutes to change it from S/C to bracket mode...
I sold my plate stop and prefer the inline....
Rich Biebel
S/C 1479
Stock 147R
Old 03-06-2016, 07:13 AM   #7
Robbie Welch
Liked 262 Times in 124 Posts
That's all I've ever had, been lucky enough to win a few races.
