Liked 2 Times in 1 Post
(1) USED WELD PRO-STAR 15x14 (6.5 B.S. 5x4 3/4" B.C. GM - CHEVY) $150 OR I WILL BUY YOUR WHEEL
(30) NEW AUTOLITE AG403 RACING PLUGS (3) NEW BORLA SS COLLECTOR MUFFLER (40728) 2 1/4" PRIMARY TUBE $275 ea orW/Deal for 2 ---- (1) POLISHED PG TRANS SHIELD OUT OF SFI DATE $50 ---- (1) SET BBC 4 BOLT MAIN CAP'S AND BOLT'S $100 ---- (1) 8 1/4" MOPAR REAR 4:56 GEAR SET GEARS AND INSTAL. KIT $250 -- (1) 1993 DODGE DAKOTA ECU MODIFIED AT MOPAR 5.2 MAGNUM MOTOR RAN 12.46 et W/THIS ECU --- $250 CHEVY BLOCK'S: 1) 283 APART FOR INSPECTION 1) 283 COMPLETE MOTOR STILL TOGETHER (1) NIB PRECISION GEAR 4:10 RING/PINION FOR GM 7.5 (MONTE CARLO CUTLASS etc) $125 (1) MALLORY DUAL POINT TACH DRIVE DISTRIBUTOR #2664501 (USED) $250 (1) MALLORY UNI LITE CHEVROLET DISTRIBUTOR (USED) $250 (1) TCI 6" ALL ALUMINUM BB CHEVY BALANCER $100 (RED ANODISED) 16) BIG BLOCK CHEVROLET ROLLER LIFTER's W/LINK BAR's $250 (1) JONES MECHANICAL TACH & CABLE -- $150 (1) MOROSO MECHANICAL TACH - MOUNTING BRACKET - CABLE --- $250 (4-5) ASSORTED FORD TOP LOADSER CLUTCH DISC AND PRESSURE PLATE'S (1)MOROSO 89552 0-15 LB 4" TIRE PRESSURE GAUGE NIB - $120 OBO (1)MOROSO/COMPETITION ENGINEERING (NEW) C4010 MUSTANG LATERAL ENGINE LIMITER - $54 (1) RONCO CHEVROLET MAGNETO W/TACH DRIVE - $900 (1) OLDER ACD BOX (BLACK) (1) ACD #7500 CO2 BOTTLE NEW AND NEVER USED - $60 (1) MSD # 8738 TWO STEP (2STEP) -- $55 (1) NEW IN THE BOX NEVER USED MSDPRO POWER COIL #8201 - $100 (1) DEDENBEAR TSC-4 THROTTLE STOP CONTROLLER (1) DEDENBEAR DOMINATOR TS-5 (UNDER THE CARB) 4 BLADE THROTTLE STOP - (PRIMARY & SECONDARY) $300 (1) HOLLEY LIST # 3310-5 --- 750 CFM, MANUAL CHOKE DUAL FEED FUEL BOWLS, SQUARE BORE --- $150 1) HOLLEY LIST # 4412-2 -- 500 CFM TWO BARRELL MANUAL CHOKE --- $150 (1) NEW NEVER USED PINGEL RETRACTABLE TOW STRAP --- $115 (1) 1 NEW IN THE BOX SUNCOAST PERFORMANCE 1927 FORD ROADSTER WINDSHIELD KIT COMPLETE --- $150 (1) CHEVROLET BB RECTANGULAR PORT INTAKE # 6269378 JUST SQUARED -- $125 (1) NIB 1962-1965 CHEVY NOVA REAR WINDSHIELD GASKET (2) NIB 1962-1965 CHEVY NOVA CHROME DOOR MIRRORS W/MOUNTING HARDWARE (2) (TAKE OFF)M/T RADIAL STOCKER SLICK'S --- both set 30x9x15 (2) (TAKE OFF) GOODYEAR RADIAL STOCKER SLICK'S (2) M/T 29.5x9.0x15 (3056) WITH TUBES ONE SEASON OLD AND NOT USED WEEKLY - $300 CALL 508-TWO SIX NINE-9611 MORE TO COME DRAG RACE - STREET RACE - HI PERFORMANCE - MOPAR - FORD - HOT ROD - PRO/STREET - PRO STREET - SUPER GAS - NHRA - IHRA- HOLLEY-STOCK CAR - MOROSO - MUSTANG |
