Old 01-20-2016, 03:42 PM   #1
kellintrans
Default Junior Stock Enthusiast
I am posting this to gauge the level of interest in establishing a Mid-Atlantic based drag racing association for the purpose of real and affordable stock style class racing.
The criteria for racing would be based on the rules and regulations as they pertained to the Junior Stock eliminator classes of the 1960's thru the early 1970's. However, it will not just be limited to the cars of that time period, but with makes and models from 1955 thru today (with some exceptions).
The IHRA and various muscle car clubs do have a similar Pure Stock class, but it is limited to IHRA only events and/or limited as to the cars that are eligible.
The basis for this association is not for nostalgia or profit, but to recreate a true entry level class for real stock cars to compete. Ingenuity and attention to detail would take priority over money spent. Stock would literally mean stock, and it will be up to the racer to make the combination work within the given set of rules.
The NHRA/IHRA stock eliminator classes are no longer entry level, affordable, or even stock for that matter. This is not how the class was originally intended.
If there is enough interest in this type of racing, formal rules and guidelines can be drafted, index's can be set, etc...
Any input or suggestions are welcome.
kellintrans is offline   Reply With Quote
Old 01-20-2016, 04:47 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Junior Stock Enthusiast
I would like to help..
D
Old 01-20-2016, 05:44 PM   #3
kellintrans
Thanks!! Any help or ideas are greatly appreciated. I have read your various posts, and I know your are quite enthusiastic about Junior stock racing.
Old 01-20-2016, 06:45 PM   #4
Dan Fahey
Dan Fahey's Avatar
Thanks..!
IMHO... Pure Stock and PureStockDrags and FAST Classes come close to what you are asking.
The Limiting things should be Full Exhaust, Headers allowed, Limited Valve Spring (IHRA), which limits the Cam, (IHRA), register-able and legal to drive on the road.
IHRA Pure Stock is so close to what you are asking about.
A and Pure Stock may require Roll Bars for the 11.49 et rule.
Here a Crate Engine replacement for Pure Stock would help some of the older cars.
Just got to limit which ones. Most engines did not have much cam lift.
Such as installing an early 302 4bbl in an early Mustang where the 289 maybe tough to find.
Pure Stock or Jr. Stock should not have super stressed Stocker engines.
Should be able to convert many of the collectable cars with simple upgradable bolt on mods for safety. Such as front disk brakes.
For Decades drove my car to many a bracket race and since 2010 IHRA Pure Stock until mid last year.
D
Old 01-20-2016, 07:31 PM   #5
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
In 1970.....Lebruns A/S'er ran around 11.40 at maybe 120 on 7" tires....at a stocker event at Island....We raced him with our H/S Chevy II and my driver fouled and both cars went .05 under the record. It's a vivid memory as I was standing right behind the starting line and it was 3rd or 4th rd....
I am just not sure whether his car was a Camaro or Corvette....just to long ago.....and he had numerous cars over the years....
I don't know if they ever ran in the 10's but it's possible.
Pistons and rings were less restrictive on the rules than the later version of stock..
Regrind cams were widely used...
Highly likely people were getting very creative even though getting caught was WAY more likely back then....
Rich Biebel
S/C 1479
Stock 147R
Old 01-20-2016, 08:37 PM   #6
Dan Fahey
Dan Fahey's Avatar
That was excellent then.
Today he would run close to a second faster.
Better tires, track surface, suspension, low drag rings, converters.
IHRA allowing a very small wag on the springs.
Old 01-20-2016, 07:44 PM   #7
kellintrans
Thanks..!
D
Dan,
I agree about IHRA Pure stock. I am building a car to compete, hopefully, someday. It is just an IHRA class, though, and the cars eligible are pretty limited. I guess I am looking to do something similar to what MANDRA does, but solely for a Pure Stock style vehicle with index's, weight breaks, etc..
Old 01-20-2016, 05:49 PM   #8
Greg Gay
Liked 286 Times in 73 Posts
I think I understand where you are trying to go, but I'm not sure that the old Junior Stock rules are where you want to be. In some ways, those rules were less restrictive than what followed them. For example, I believe that Dave LeBrun's Corvette ran in the 10's as a Junior Stocker, and it was many years before a Stocker ran in the 10's under the new rules. Junior Stock disappeared after the 1970 season, and there was no Stock in 1971. The new Stock rules came out in 1972, and they were the most restrictive a that point. At first, full exhaust and no slicks were required, and even lightweight, racing wheels were not allowed, although many did appear. Next came "cut exhaust", but still through stock exhaust manifolds, and the rest of the exhaust system still had to be in place. After a year or two, narrow slicks (or a wider street tire) were allowed, and the rules slowly became more and more liberal. The 1972 cars were basically a blueprinted engine, shift kit, and rear axle gear change.
I think your class has merit, but I see that you basically have two ways to go with it: You can either go with classes, indexes, and heads up runs. Be prepared to have tear downs, as there is only one way to go faster. This will not be inexpensive. Your second option is a class that looks stock, possibly even "sounds' stock (cam restrictions), but has only one class, everyone dials in, and each individual's cost is what they want it to be. This would be somewhat similar to the Factory Appearing FAST class, but with dial ins, you wouldn't have to be that fast. However, then you might need to put a minimum dial in in place, so as to keep absolutely pure stock cars from driving in off the street, and entering.
Greg Gay is offline   Reply With Quote
Old 01-20-2016, 07:31 PM   #9
kellintrans
I think a minimum dial will have to be in place in any scenario. Otherwise, it is just a regular bracket race.
The Pure Stock Muscle Car drag race has an interesting format (rules and tech), but in this case allow more than just factory muscle cars to participate. In this case, the rules for this class could be more liberal regarding slicks, open exhaust, gear ratio changes, etc.
As far as tear downs, any competitor questioning the legality of another car would have to put up a predetermined amount of money that would be refunded if violations are found, or paid to the racer being torn down if they are legal.The car could also be torn down if there is a suspicion of blatant cheating by the organizers. Otherwise, a gentlemen's agreement could be in place. Anyone found cheating would be fined and/or banned from competing.
