Old 10-18-2015, 11:01 PM   #1
rick lester
Liked 4 Times in 1 Post
Default 1978 Dodge Magnum stocker?
I love oddball combos, this might not be an oddball but I would like to get an opinion on if this is viable. Its heavy, can be run as a 2 brl or a 4brl with a intake /carb switch (same cam and heads for either). Wants a grand but probably can get it for 600 or so. IF I do pull the trigger, you can count on a post by post build up here. N/O/P as a 2brl, L/M/N as a 4brl.
rick lester is offline   Reply With Quote
Old 10-18-2015, 11:17 PM   #2
rick lester
Default Re: 1978 Dodge Magnum stocker?
Tried to make the picture bigger but I failed miserably.
Old 10-19-2015, 07:56 AM   #3
Billy Nees
Liked 7,909 Times in 1,754 Posts
With the 4bbl it's OK but the 2bbl would need about 20 HP back to be worth your while.
Billy Nees 1188 STK, SS
Old 10-19-2015, 12:03 PM   #4
Liked 5,153 Times in 1,967 Posts
Agreed
gif image hosting
Old 10-19-2015, 01:35 PM   #5
Paul Wong
Liked 419 Times in 85 Posts
the 360 270hp is the way to go. It would run under the index cheap.
Paul Wong is offline   Reply With Quote
Old 10-21-2015, 08:41 PM   #6
Greg Reimer 7376
Liked 721 Times in 221 Posts
Cool Re: 1978 Dodge Magnum stocker?
Listen to Paul Wong. Incidentally,do these cars have the long straight front torsion bars,or the removable front K member with the bent bars contained in it?
