Liked 4,390 Times in 506 Posts
I am currently running a very heavy duty Powermaster 140amp alternator with a 3 inch pulley and the thing has to be at least 15lbs so I was wondering what most guys use for alternators in stock. The car has EFI so I need something that charges adequately.
Liked 230 Times in 75 Posts
I run the small denso it weight about 6lbs and is a one wire deal. I will let you know where I get them as soon as I remember have it in my favorites on my other computer. I think I still have your number in my phone will send you a picture.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
Liked 237 Times in 126 Posts
I have a street machine built to GT/MA standards and I have had a ton of trouble trying to get an alternator to keep up with all the electrical demands of it. My current one is a 100 amp TuffStuff one wire that seems to be up to the task. Weight is an issue and it puts a strain on my aluminum heads with the current mounting bracket. The Denso form factor is nice but I don't think they would power my needs with full time lights, fuel pump, water pump, fans and a vacuum pump for the brakes.
I had a 140 amp Powermaster that came out of the box with the case bolts falling off. They looked like they had been bathed in acid and the nuts just sheared off with my finger tips. Nice return from Summit. Dale
Liked 47 Times in 21 Posts
Call Mark Payne @ House of Payne Performance 540-471-0471
Monday – Friday 3:00 PM to 8:00 PM (EST) Saturday 8:00 AM to 8:00 PM (EST) By Mail: House of Payne Performance 2432 Hermitage Road Waynesboro VA.22980 |
#5 | |
Liked 204 Times in 54 Posts
By the way: Noticed you qualified number 2 last weekend at over a second under. Fast car. |
Liked 223 Times in 73 Posts
Here is the link this is the alt that I use. I took to a local alt shop and the put a 1 wire regulator in it for me for $25 DB may have them I am not sure can call and ask. This is small and light 30 amps. I change my pulley over to a serpentine belt. Have been using this for a couple of years now with out any problems on an efi car. let me know if anybody has anything better?
http://www.dbelectrical.com/p-4720-k...231-64012.aspx
Liked 216 Times in 77 Posts
Any chance you would tell me where you found a serpentine pulley that will fit it. I have been wanting to do the same thing.
Thanks |
