Old 09-16-2015, 08:29 PM   #1
Vinnie78
Default Cal tracts
starting adjustments upper or lower hole . In the upper hole they are heading up in the lower hole they are almost level .
Vinnie78 is offline   Reply With Quote
Old 09-17-2015, 08:23 AM   #2
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default Re: Cal tracts
The starting point Calvert recommends is to use the hole that keeps the bar closest to parallel with the ground with the car on the ground and at race weight.
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 09-17-2015, 01:32 PM   #3
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Cal tracts
That's true,,, race weight also means having a butt in the seat,, whoever the driver will be. For a baseline start, they recommend front shocks full loose, rear shocks on tightest ext setting, put bars in upper hole with 1/16" gap preload- go test.
A. Hooks the way you want: good to go, no more adjustment needed.
B. Hooks but too much wheelstand: tighten front shocks.
C. Hooks but goes left or right: add small preload to direction it goes, until straight.
D. Hooks then spins: loosen rear shocks 1-2 clicks, til it stays on the tires.
E. Hooks but hits too hard: go to lower hole and repeat A-D.
Softest hit: lower hole- no preload
Soft hit: lower hole- 1-5 turns preload
Hard hit: upper hole- no preload
Hardest hit: upper hole- 1-5 turns preload.
Hope this helps,, good luck and let us know how it went. The Cal-Tracs is a great system, especially if you use their split springs and shocks. My 2 cents
Danny Durham
Old 09-17-2015, 01:54 PM   #4
mykids
Liked 2 Times in 1 Post
Don't mind me I am having a Senior moment but if I were to put my bar's in the upper hole doesn't that blow the theory about being "parallel with the ground" - just a question from an OLD F_ _ T because I alway's felt that the bar's should be in the upper hole to hit harder but we haven't been out yet to test - Looking forward to a response to help this Old Guy as well -- Thank's In Advance
mykids is offline   Reply With Quote
Old 09-17-2015, 03:51 PM   #5
FLEMING
Liked 55 Times in 26 Posts
I set mine per travis at Calvert..
Lower hole 1/4 turn of preload both sides with driver in car.. My car almost drags the bumper.. Keep in mind if you dont add travel to the front end and have a loose on extension shock on front it wont matter where your bars are set..
FLEMING is offline   Reply With Quote
Old 09-18-2015, 09:50 AM   #6
Vinnie78
Thanks for the feedback I will be testing for the first time this wens day night . I will let you know how it goes . I have a set of drag radials an a pair of slicks I'm concerned about the slicks the have some dry rot cracking in the sidewall . On one side of both tires . Not sure if I trust them . Any comments on that ?
Old 09-18-2015, 10:40 AM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,967 Times in 595 Posts
If you don't have some good tires you will probably be disappointed. Also the testing will be a waste of your time and money. I would wait and get some new rubber on that car before testing.
Mike Pearson 2485 SS
Old 09-18-2015, 08:05 PM   #8
Vinnie78
Thanks your rite bad tires are a waste of time . It's crazy to buy a set of new tires now. We only have a few more test nights left with decent weather . I might be able to borrow a set to try .
