Liked 173 Times in 52 Posts
I have a 24ft enclosed trailer with an untreated, unpainted floor. Been kicking around putting a snap together floor like 'Race Deck' or 'Swisstrax' but I've not seen it used in a trailer before. I've seen some with spray on bedliner which is ok but I know it can be slick under some conditions. Not crazy about the vinyl checkerboard.
Saw this stuff, ArmorSeal Tread-Plex Water Based Coating, looks interesting. As usual I'm probably over thinking this a little. Thoughts and opinions are appreciated Kelly |
Liked 333 Times in 180 Posts
your question really all comes down to PRICE-- how much do you have to spend??? There are multiple options for finishing the floor some not overly expensive coverings might be (paints etc.) to very expensive coverings (Coin type vinyl/rubber flooring or aluminum diamond plate) its the look you want to achieve and the amount of money you have to spend on your floor--FED 387
Liked 54 Times in 27 Posts
cost, and weight! I just used latex based paint on mine, easy to touch up, and fine unless you create an exxon valdez on the floor.
Liked 33 Times in 20 Posts
My neighbor at NMRA Bradenton has installed laminate wood flooring.
He had it installed over the plywood floor and finished the edges with 1/4 rounds. It looks really good. The car was a light weight mustang, big slicks. |
Don't use aluminum diamond plate it's extremely slippery when wet!
![]() I have used indoor out door carpeting but you need to glue it down and it's a PITA to remove. Cheap vinyl tile will not hold up for long. I haven't tried vinyl flooring yet. I would at least paint it.
Bill Baer 3391 SC, 339B SC, QR Last edited by Bill Baer; 03-19-2015 at 08:44 PM. |
#6 | |
Liked 1,948 Times in 589 Posts
any sort of vinyl tile or flooring will not hold up. There are some rubber type tiles that would but the cost would probably be as much as the tread plate.
Mike Pearson 2485 SS |
