Liked 26 Times in 10 Posts
GARAGE SALE SICK OF WALKING OVER/AROUND THESE PART'S:
(2) USED WELD PRO-STAR 15x3.5 SPINDLE MOUNT WHEEL'S WITH ALL HARDWARE $225 (1) NEW IN THE BOX WELD PRO-STAR 15x3.5 SPINDLE MOUNT W/HARDWARE $200 (1) NEW WELD PRO-STAR 15x14 (6.5 B.S. 5x4.5 B.C. FORD/MOPAR) $250 WILL SELL (1) USED WELD PRO-STAR 15x14 (6.5 B.S. 5x4.5 B.C. FORD/MOPAR) $150 BOTH $350 (2) NEW 1 7/8" HEADER COLLECTOR'S $40 ---- (2) USED DYNAMAX COLLECTOR MUFFLERS 2" PRIMARY TUBE HPC COATED W/EVAC BUNG'S $225 ---- (3) NEW BORLA SS COLLECTOR MUFFLER (40728) 2 1/4" PRIMARY TUBE $275 ea orW/Deal for 2 ---- (2) USED CHASSIS ENGINERING REAR COIL/OVERS W/O SPRING'S (15 1/2" OPEN 11 1/2" CLOSED) $125 ---- (1) POLISHED PG TRANS SHIELD OUT OF SFI DATE $50 ---- (1) CSI FLEXPLATE SHIELD WITH ALL THE HARDWARE OUT OF DATE BUT IT CAN BE RE-CERTIFIED $45 - (1) CSI P.G.SUPERSHIELD WITH ALL THE HARDWARE (1) NEW MOPAR PERFORMANCE PINION SNUBBER FOR AN 8 3/4" REAR $50 ---- (1 SET) BBC 4 BOLT MAIN CAP'S AND BOLT'S $100 ---- COMPLETE 8 1/4 REAR DRUM to DRUM W/4:45 GEARS AND SPOOL UNBREAKABLE AXLES MEASURE'S 54 3/4" BACKING PLATE to BACKING PLATE --- CENTER PIN to CENTER PIN 43" -- (1) SB CHRYSLER LAKEWOOD BLOWSHIELD BELL W/CLUTCH FORK - ZBAR & BLOCK SAVER PLATE $150--- (2) TWO 15x8 WELD PRO-STAR WHEELS 5x4 3/4 BC WITH 4 1/2 BS - W/HOOSIER 9x30x15 STOCKER SLICK'S THAT ARE TIRED $350 - (2) WELD ALUMA STAR's 15x12 - 4 1/2" BC W/WO M/T ET STREET RADIAL SLICK's 31x13.50x15 (DOT SLICK's) NEVER ON THE TRACK (4) WELD PRO STAR WHEEL'S 2 --- 15X14 WHEELS W/3" BS AND A 5on 4 1/2" BOLT CIRCLE HAVE BIG PRO/STREET TIRE'S MOUNTED --- 2--14x6 WELD PRO STAR'S W/STREET TIRE'S WERE MOUNTED ON MY PRO-STREET ROADSTER (1) NIB PRECISION GEAR 4:10 RING/PINION FOR GM 7.5 (MONTE CARLO CUTLASS etc) $125 (1) MALLORY DUAL POINT TACH DRIVE DISTRIBUTOR #2664501 (USED) $250 (1) MALLORY UNI LITE CHEVROLET DISTRIBUTOR (USED) $250 (1) TCI 6" ALL ALUMINUM BB CHEVY BALANCER $100 (RED ANODISED) (15) SMALL BLOCK CHRYSLER (318-340-360) ADJ ROCKER ARM's/SHAFT's(USED) $130 (16) BIG BLOCK CHEVROLET ROLLER LIFTER's W/LINK BAR's $250 (1) JONES MECHANICAL TACH & CABLE (4-5) ASSORTED FORD TOP LOADSER CLUTCH DISC AND PRESSURE PLATE'S CALL 508-TWO SIX NINE-9611 MORE TO COME DRAG RACE - STREET RACE - HI PERFORMANCE - MOPAR - FORD - HOT ROD - PRO/STREET - PRO STREET - SUPER GAS - NHRA - IHRA |
Liked 216 Times in 77 Posts
on the 1 7/8 collectors. How big is the outlet ? (IE 3, 3 1/2) Are they new or used?
Liked 2 Times in 1 Post
3 1/2"
