Old 02-03-2015, 03:57 AM   #1
Bernhard
Default Pure stock and cam lobe design?????
So the engine I would like to build for Pure stock has a valve spring pressure of 120 closed 300 open.
.475 lift and a rpm range 5500 to 6500
So is the cam profile designed around the valve spring because it is the limiting factor?
Are these questions for the cam company and engine builder/parts supplier?
Bernhard is offline   Reply With Quote
Old 02-03-2015, 07:44 AM   #2
bigfoot584
Default Re: Pure stock and cam lobe design?????
I don't think I'd worry about springs, with 4.75 lift I worry
about a block large enough to handle the lift LOL.
You really meant .475 lift, I hope.
bigfoot584 is offline   Reply With Quote
Old 02-03-2015, 12:59 PM   #3
Bernhard
Yes .475
How do the IHRA measure spring pressure, is it at the factory installed height ?
Old 02-03-2015, 01:23 PM   #4
Tar Heel
Guest
Posts: n/a
Originally Posted by Bernhard View Post
Yes .475
Yes it is.
Call Bullet and ask for John. He is a Stock guru and ground us a Pure Stock cam that we were very happy with and helped the car a bunch while still remaining legal.
Scott
Old 02-03-2015, 01:36 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
If they do it like NHRA did when they were still checking, they willl measure the installed height of the valve spring on your engine when the spring is removed and that is the height they will use to check the pressure of the valve spring. The specs will give a seat pressure and a pressure at a designated height and the inspector will use the difference to check the spring rate.
Example: Common SBC spring was spec'd at 84 lbs on the seat @ 1.700" and 206 lbs open pressure @1.250". That's .450" difference between the seat and the open spec. The tech measures the installed height on your engine of the spring he removes and finds that measurement to be 1.765". He uses a micrometer type instrument on a valve spring pressure checker to find out the pressure of your spring at 1.765". If it is 84 lbs or less, you're okay. Then he compresses the spring an additional .450" and your spring should be less than 206 lbs.
They are concerned that you are not exceeeding the pressure specifications, not the factory specified installed height.
