Old 01-30-2015, 11:45 AM   #1
Tony Corley
Liked 61 Times in 25 Posts
Default IHRA Pure Stock Classification?
While in the middle of my NHRA Stock build, I have another car that I would like to possibly run in IHRA Pure Stock. After reading the rule book, (Pure Stock rules are very vague, lol), I still don't see where to find classification and blueprint info for IHRA. 1989 Mustang LX 5.0 Coupe. Thanks in advance.
Tony Corley is offline   Reply With Quote
Old 01-30-2015, 12:53 PM   #2
Tar Heel
Guest
Posts: n/a
Default Re: IHRA Pure Stock Classification?
If I'm not mistaken the classification follows NHRA's numbers and can be found on their web site. Regarding which class it will fall under then you can look at the IHRA web site to see the rule book. The indexes will also be listed there once you determine the class. The rules are pretty close to traditional Stocker rules except you must either run a full exhaust (or no exhaust but with stock manifolds), cam must remain OEM for lift AND duration, no electric water pump, and a couple other small items.
Scott
Old 01-30-2015, 01:02 PM   #3
Tony Corley
Thank you, that's pretty much what I read in their rulebook, just wasn't certain how they classified (couldn't find it on the website, but I'll keep looking) and what they used for blueprint specs. Like specifying valve springs rates, etc., since they say they must be the same as from the factory.
Old 01-30-2015, 03:03 PM   #4
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Tony,
Email Mike Baker at IHRA And ask him to send you the tech sheets for your combo. Unfortunately, (it should be more available) this is the only way to get the info you need. mbaker@ihra.com
Hope This Helps....
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 01-30-2015, 06:21 PM   #5
Tony Corley
Thanks Steve, that's what I was looking for.
