Old 01-19-2015, 12:04 PM   #1
Marco
Liked 4 Times in 1 Post
Default Valve springs HELP HELP HELP
I have an 88 Camaro J/SA TPI 230/264HP 350 for those of you who may recall it's the late great Jim Harringtons old car. I am trying to replace the valve springs and I have no idea what I'm looking for could anyone tell me what springs I need for this motor size, type, brand, part number whatever.
The car has developed a miss right at the shift points and I've checked everything I can possibly think of and this is the only thing I can come up with being the problem.
Thank You in advance,
Mark Young
Marco is offline   Reply With Quote
Old 01-19-2015, 12:23 PM   #2
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Valve springs HELP HELP HELP
Marco,
Call Bud Rowe @ 252-633-4084 , he can help you out ... I think that's one of his old cars anyway ?? LOL
Dave Ribeiro 1033 STK
Old 01-19-2015, 12:26 PM   #3
Marco
Default Re: Valve springs HELP HELP HELP
Thanks Dave I did already he and Brian are out of town today and I was trying to get something ordered today if I could.
Old 01-19-2015, 02:07 PM   #4
Joe Schaechter
Joe Schaechter's Avatar
Liked 13 Times in 4 Posts
Here is thread from last year about the PAC1409X springs. We abuse them regularly in our Chevy II stocker!
http://classracer.com/classforum/sho...d.php?p=421373
Joe Schaechter 3168 STK
Joe Schaechter is offline   Reply With Quote
Old 01-19-2015, 03:51 PM   #5
J.R. Haddad
Liked 1,471 Times in 308 Posts
Mark, we have the same combo and went with Comp. Cams conical
springs. Give Tim Cole @ CompCams a call and he will look after
you well. J.R.
J.R. Haddad is offline   Reply With Quote
Old 01-19-2015, 05:09 PM   #6
TurboBuick6
Marco,
Feel free to call us (PAC) at 866-799-9417 ask for Matt. I will tell you the same thing Jim said. It's a tried and true combo.
TurboBuick6 is offline   Reply With Quote
Old 01-19-2015, 07:24 PM   #7
PJ305
Liked 5 Times in 4 Posts
Does it have a miss in high gear? What RPM do you shift at? I don't believe the tune port likes a lot of RPM's like the carb engines do.
PJ305 is offline   Reply With Quote
Old 01-19-2015, 07:37 PM   #8
Marco
Shift it at 58 and 6000 and once the rpm gets back up to around 6 it returns
almost sounds like a fouled plug when it does it
Old 01-22-2015, 09:56 AM   #9
Marco
Turbo Buick PM sent
Old 01-22-2015, 11:39 AM   #10
Signman
Liked 269 Times in 99 Posts
Marco
Know a little bit of the history of that car. Is your engine flat top or dish piston with 083 head? The HP you provide would be for the dish piston I believe.
Your high RPM miss can be the valve springs but the only real way to know is to take off a couple and check open and seat pressure. The hot ticket right now is conical springs, they have some good qualities but unless this is a max effort conventional springs at lower cost still go down the track.
Check evertything in your ignition. Don't assume because it new it's good.
One time I was having problem with the car slowing, after fixing it was slowing up again! The distributor was not tightened completely when syncing with ECU trying to find the first problem.
Look for dumb stuff.
Look over your fuel and timing maps to be sure nothing was changed by mistake; look over your set up in the software to be sure everything is as it should.
Ask me why I know this.........
Make sure you have fuel pressure and volume, it will miss upstairs if it's real lean. If you data log Air Fuel Ratio it will indicate, if you don't you should. Check the plugs too.
