Liked 225 Times in 88 Posts
Looking at the strange web sight it doesn't state wheel stud hole dia. 1/2" or 5/8" of there disc hat for gm 12 bolt . Aerospace sales both 1/2 or 5/8 . Wilwood looks like only in 1/2 holes ? M/W is a yes . Anybody got any info ?
Liked 11 Times in 8 Posts
I had to drill out my Wilwood hats for the 5/8 studs for a Dana 60. I used a Unibit step drill bit.
Liked 99 Times in 60 Posts
Ken, all strange rotors are for the 5/8" studs. Strange has a sleeve to adapt to 1/2" if needed.
On the Strange web site note all the brake photos show with studs and nuts. If you scan the site for stud options you will set the 1/2" stud kits with "sleeves" I have a Strange brake kit for the Super 10 build with 5/8" studs. I installed a symmetrical end on the 12 bolt housing.
Larry Woodfin 471W |
Liked 336 Times in 183 Posts
put the 5/8 in you will never break a stud in a Stocker or LOW HP SS-- got access to a machine shop enlarge the hats to 5/8 inch-- problem solved
X2.........I have broken 1/2 on HEAVY Stocker and
disaster results ( Especially to the Tree )
Liked 285 Times in 87 Posts
Liked 237 Times in 126 Posts
All the Strange rotors look like they have 10 holes of two sizes. We are talking rotors - disk hats - right? Call them.
Dale |
The above post by Dale is correct. I doubled checked this morning, the rotors I have for the Super 10 have both bolt patterns.
I always find it surprising when you can look at an item yet never catch all the details. When you are looking for one specific fitment [it fit on my 5/8" studs] there was no reason to notice the second set of holes.
photo of Strange brake rotor with dual bolt pattern
