Old 07-23-2014, 03:41 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Staggered rear coil over springs?
In trying to eliminate the right rear squat on the super stocker, is it worth putting a stiffer spring on right side. Right now have 110lb in both and was going to put a 130 on the right. Also have a 150 if we decide to try that. Anyone ever done this? I hear yes and no but I know for the 5.0, many spring manufacturers make stiffer right springs..
'65 Mustang SS/L & L/SA
Old 07-23-2014, 06:28 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Staggered rear coil over springs?
Bobby, I did that with a '65 Chevelle Convertible I had way back when. An air bag in the right rear spring worked better for me. Stiffer rear coils made mine much more prone to wheel spin.
Ed Wright 4156 SS/JA
Old 07-24-2014, 07:03 AM   #3
Robert Simpson
Liked 20 Times in 12 Posts
Bobby,
Do you have a sway bar or "Anti roll bar" on the rear of your SS/L car? I believe one of those would eliminate the body roll without changing the springs shocks etc. S&W makes a nice universal one I believe.
Robert
Robert Simpson is offline   Reply With Quote
Old 07-24-2014, 10:36 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
I would assume your car is either ladder bar or 4 link. If the geometry is right you should not have any squat. The springs only hold the cars weight. My car weighs 3220 and I have 130 lb springs on my shocks and they are to heavy. really need 110's. I would recheck the rear suspension to make sure there is no bind and everything is adjusted properly.
Mike Pearson 2485 SS
Old 07-25-2014, 09:20 AM   #5
TurboBuick6
Like robert said, if you are not running a sway bar or a bar too small, that is where I would start.
TurboBuick6 is offline   Reply With Quote
Old 07-25-2014, 10:23 AM   #6
Bimbo Jones
65 Chevelle 3150 lbs. wagon w/350 &t-brake. Aftermarket control arms, one inch sway bar and air bag at the right rear. The car goes through a bunch of body roll at the hit and then squats quite a bit but hooks pretty good for only using 9" slicks. I'm just lucky after all these years an thousands of passes it still hasn't cracked the windshield from its torqueing wheel standing launches. Looking forward to following this thread to see if any bolt on solutions work well at controlling the car squatting at the right rear.
Bimbo Jones is offline   Reply With Quote
Old 07-25-2014, 03:02 PM   #7
Liked 5,138 Times in 1,961 Posts
I wanted to bring this one back before this thread gets too far off course.
Old 07-25-2014, 04:35 PM   #8
Bobby Fazio
Ladder bar, qa1 coil over setup. Car has squatted right rear since the 70s.
