Old 07-01-2014, 11:06 AM   #1
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default It's Timing Light time!
After what I think is 20-plus years, my timing light has finally stopped working! It was a self-powered model, of nondescript manufacture, that gave me great service. I run an MSD distributor/6AL-2 set-up. What would you recommend that might be a good replacement?
Thanks in advance for your suggestions!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 07-01-2014, 11:23 AM   #2
jmantle
Liked 172 Times in 81 Posts
Default Re: It's Timing Light time!
My old Mac timing light didn't seem to like the MSD ignition so I bought an MSD timing light. Works great.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 07-01-2014, 11:33 AM   #3
Doug Domm
Liked 84 Times in 21 Posts
At one time MSD suggested in their bulletins a craftsman timing light. I can't recall the model no. it looks the same as their light which leads me to believe the MSD light may be repackaged. It is not self powered and no built in advance. I think Sears still sells that same light. I bought one a long long time ago and it still gives me good service. I can check on my model no. If you like. I bought a second one a couple years ago off eBay just to leave in the trailer.
Doug Domm is online now   Reply With Quote
Old 07-01-2014, 01:03 PM   #4
carl hinkson
Liked 18 Times in 10 Posts
Flaming River self powered light works great with MSD. Not many dial back lights except the MSD light will with multi spark systems.
http://www.chevytalk.org/fusionbb/sh...hp?tid/173877/
http://www.dragracingonline.com/tech...-lights-1.html
carl hinkson is offline   Reply With Quote
Old 07-01-2014, 02:18 PM   #5
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Thats what I have ( Flaming River) and it works great!!!!!
Bob Bender 144 O/SA
Old 07-01-2014, 03:07 PM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
My nearly 30 year old Snap On, "Computerized" dial back timing light like this one...
http://www.ebay.com/itm/SNAP-ON-TOOL...f#ht_398wt_867
has always worked with every MSD ignition I've had.
That said, I also have a MSD Self-Powered Timing Light.
Old 07-01-2014, 03:16 PM   #7
FED 387
Liked 335 Times in 182 Posts
Get a Sun!!! mine is at least 35 years old still works perfectly-must be a XENON inductive light--- forget dial type--- time it above 3000 RPM--A good Sun will work in direct sunlight no need to get under a blanket although if you get in the direct sunlight a towel to shield over the balancer might not be a bad idea--with my Sun the clamp that fastens on to the plug wire has an arrow on it and you must have the arrow pointing in the correct direction or it will not read correctly---
Old 07-02-2014, 07:38 AM   #8
joespanova
Liked 13 Times in 11 Posts
The Summit version is the same light.........I have one , works great when / if RF is an issue.
http://www.summitracing.com/parts/su...9-13/overview/
Old 07-02-2014, 01:20 PM   #9
NHRA 303
NHRA 303's Avatar
If you are running a 16v system. Make sure you power the light off of the step down. Ive fried 2 already. The second one i just forgot. Oops! Your alternator is putting out 19. Steve-o-
Steve Tucholsky
NHRA 303 is offline   Reply With Quote
Old 07-03-2014, 03:32 PM   #10
carl hinkson
There are some Chinese knock offs beware.
