Old 05-12-2014, 12:05 AM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default P/G adjuster rod
I've got a stock P/G case that came with a car I bought. It has the hole for the band adjuster bored slightly over sized. Still has the stock threads, but down in the case the hole is larger, all the way through, than another stock case I have compared it to.. It has a rear roller bearing, too.
I was told it had a harder over sized adjuster rod for high apply pressure on the low band. Have you ever heard of such a part? Who sells it if you have? I hate to scrap the case because the rod moves around too much.
Adger Smith (Former SS)
Old 05-12-2014, 02:11 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: P/G adjuster rod
Adger,
Scotty Stites will known and if there is such a thing he will have it or can get it 662-587-3606.
I know about a heat treated adjuster but "so far" have not heard of an oversize.
Larry Woodfin 471W
Old 05-12-2014, 02:13 AM   #3
Dragsinger
another option
https://www.tsr-racing.com/
Larry Woodfin 471W
