Liked 251 Times in 125 Posts
Years ago, generally, different weight steel flywheels were used for launching a drag car. Aluminum flywheels were used for circle track cars, to accelerate quicker, not having to worry about the launch. (At least that's the way I always had heard it.)
Are aluminum flywheels used in drag racing these days? (Or before?) I see a lot of them for sale, and with the advent of adjustable clutches, I was wondering if maybe the combination of aluminum flywheel and adjustable clutch (base and centrifugal) has changed things. |
http://www.advancedclutches.com/metalcoverclutches.htm This is a link to pictures that show the extent that they go to to reduce flywheel weight. ---Trevor
Liked 1,948 Times in 589 Posts
Back when I ran a stick in my car which was before all of the good clutches of today the difference from a 14 lb aluminum flywheel with a steel face to a 25 lb steel wheel was 2 tenths. This was in SS/J. Back to back tests on the same day. Many moons ago though!!
Mike Pearson 2485 SS |
Liked 68 Times in 26 Posts
hi, BINGO, had same results also. lw is faster, simple physics!! same holds true today.
Liked 22 Times in 22 Posts
Most people say the aluminum is faster, and I'm sure in most cases it is, but in our SS\CS 291 c.i., 6.50 rear, 3.29 low, a rag street strip clutch, and a 30 lb. fly wheel was .06 quicker back to back, then a soft lock, and aluminum 12 lb. flywheel. I know, it surprised me, but then maybe we had the wrong tires, or something.
don,t have one |
Liked 3 Times in 1 Post
There used to be an old rule of thumb that said flywheel weight should be 1% of the vehicle weight. But that was back in the day of a 2400 lb. pressure plates or the discs with four pucs. They bite hard and break parts. Brian
