Old 02-19-2014, 03:44 PM   #1
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Angry Header Retention Rule Revision
As per NHRA in the latest rules update.
SECTION 20: GENERAL REGULATIONS, ENGINE: 1, 1:3 EXHAUST (Page 3) (2/18/2014) All cars vehicles must be equipped with exhaust collectors, headers, or stacks installed to direct exhaust out of car vehicle body to rear of car, away from driver and fuel tank. No part of the exhaust system may be routed through the driver’s compartment. Exhaust collectors/stacks system components must be securely fastened (i.e., metal connector straps, bolted, welded, etc.) to prevent loss of collector/stacks system components during competition. Effective Jan. 1, 2014, All removable multi-piece exhaust collectors/stacks must be securely fastened with either an NHRA-accepted header tether, or a minimum ½” (half-inch) stitch weld located on each primary tube or be permanently attached to the vehicle body or frame with positive fasteners (i.e. exhaust hangers, support brackets, bolts/nuts, etc.) such that they require tools for removal to prevent loss of collector/stacks during competition. A current list of NHRA-accepted header tethers is available on NHRARacer.com.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 02-19-2014, 03:57 PM   #2
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Re: Header Retention Rule Revision
So my nuts and bolts are good now?
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-19-2014, 03:59 PM   #3
Bob Gullett
The way I read it is all you need is a exhaust hangar and a muffler clamp per collector. Attach the hangar to the body or frame with a muffler clamp attached to the collector. $10-20 worth of parts.
68 Chevy11 327 F/S
Old 02-19-2014, 05:07 PM   #4
buzzinhalfdozen
Liked 11 Times in 8 Posts
Oh heck....just welded as set for a Super Comp racer, thought I read 1 inch stitch welds. Oh well guess it will be twice as good. Though I'll follow the rule I still absolutely do not agree with it, I built my entire car, from bending the tubing, fitting it and welding it in...but I can't be trusted to make sure my collectors don't fall off. Don't make sense to this hillbilly. Sorta like wearing a belt and suspenders, either one will get the job done. Heck actually I've got over a half inch of weld involved in my tabs so does that count if I put tabs on all 3 tubes? I'm sure a lawyer could wear them out with the wording they used.
Joe Buchanan SS/BX 3117
Old 02-19-2014, 05:16 PM   #5
jmcarter
jmcarter's Avatar
Liked 3,231 Times in 982 Posts
Wow, they just screwed the folks who developed tether systems that would meet NHRA's approval, now hangers will do. Some racers will save some $$ but was it all really worth all the angst over the last 4 months?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-19-2014, 06:00 PM   #6
Rick Bailey
Rick Bailey's Avatar
Liked 10 Times in 7 Posts
Seems like there's still the dragster owners to fleese !
Rick
Rick Bailey 3439 SC
Rick Bailey is offline   Reply With Quote
Old 02-20-2014, 01:53 PM   #7
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
I kind of read it that way too,except there probably will be another rule amendment that the hangar and muffler clamp have to be NHRA accepted.The Napa version may not qualify.LOL
Old 02-20-2014, 10:05 AM   #8
farmco r/sa
Liked 147 Times in 54 Posts
this seems nuts......
Randy Hyman. Lakewood co. stk 5394
P/SA
farmco r/sa is offline   Reply With Quote
Old 02-20-2014, 12:24 PM   #9
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Now there's a grey area in the definition of the clamp and hanger lol..I was thinking of using a 3 1/2" SS t-bolt clamp on the collector,with a piece of metal strapping to the clamp bolt,and the other side bolted/screwed to the floor.I wonder if that would be acceptable?.What a cluster**** NHRA!.
Old 02-26-2014, 02:14 PM   #10
gsa612
gsa612's Avatar
My collectors are bolted to the pri.tubes with a tabs (the old fash.way).I was going to make a "tether" ^^ with a clamp and straps to the floor.Unless I'm misunderstanding the revision,it seems like it would pass?.
