Old 01-27-2014, 11:56 AM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default dual valve springs
Considering replacing 1.677 manley triple springs to lighter 1.5 dual springs for my super stock 520 heads. Installed height is right at 2.050 and could get it to 2" if needed. Looking for recommendations regarding PAC's, Manley, comp or others. Understanding every application is different, how many runs can one expect from the dual springs and how are the springs holding up? Wanting if possible something that would last longer than 35-40 runs.
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 01-27-2014, 12:04 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: dual valve springs
#1356 PACs, dual 1.5" diameter. Last all year on mine. Mine set up at 2.1", I have Victory retainers that are std, +.050" &. -.050" hight. I use .200" long valves, the -.050" retainers get away from rubbing my rockers.
Ed Wright 4156 SS/JA
Old 01-27-2014, 01:41 PM   #3
Ed McLawhorn Jr.
thanks Ed. I was really leaning towards the PAC springs (1330 and 1356). I had thought more about the PAC 1330 spring as I don't have as much lift on my 283 (under .850). Still trying to keep coil bind close to .100. I can play with the keepers,/retainers and get installed ht close to 2.0 and end up with about 314 on seat. I too will have to deal with some .200 valves and rocker arm clearance.
Ed
Old 01-27-2014, 02:23 PM   #4
Jody Lang
Liked 92 Times in 29 Posts
Which Manley spring have you been using?
Jody Lang is offline   Reply With Quote
Old 01-27-2014, 02:38 PM   #5
Ed McLawhorn Jr.
Jody, it's a set of heads I bought used prep by layer. The spring currently on heads are the manley nextek 221447 spring. spec (350# at 2.0 installed ht.)
Ed
Old 01-27-2014, 03:49 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
Ed,
We have one engine with the PAC 1.5 springs. They have held up real good Lift is just over .800 at the valve. Installed at 2.100 we get about 350 on a new set. If your spring seats are cut for the triple springs you will need their spring positioners to keep the spring located properly to the guide. we had a learning curve on that.
Mike Pearson 2485 SS
Old 01-28-2014, 02:31 PM   #7
Jody Lang
Ed
And you're only getting 35-40 runs out of the Nexteks?
I was told by a reputable Class engine builder that some have had problems with the doubles.
Old 01-30-2014, 09:15 PM   #8
Weekend Racer
My pac #1356 are at 340 lbs.@2.075.Ten pull on dyno,30 pass. I don`t know if they drop again and again .Is there a safe limit ?
Weekend Racer is offline   Reply With Quote
