Old 01-14-2014, 09:14 AM   #1
mat H/SA
mat H/SA's Avatar
Liked 14 Times in 8 Posts
Default front end 69 nova
Hi
what type bushing ball joint etc is the best,
im looking to refresh my stuff
thanks for you help
mat H/SA is offline   Reply With Quote
Old 01-14-2014, 10:24 PM   #2
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Default Re: front end 69 nova
I don't know if it's the best but it's what we use.
Global west bushings and extended ball joints. They sell it in kit form
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 01-15-2014, 01:18 AM   #3
Todd Bailey
Liked 33 Times in 17 Posts
Matt,
Check out Howe Racing Enterprises. That have extended ball joints that go up to .9 long.
Todd Bailey is offline   Reply With Quote
Old 01-15-2014, 06:31 AM   #4
Alan Nyhus
Liked 799 Times in 236 Posts
Mat, I went with Energy Suspension urethane control arm bushings, Moog #K5250 offset control arm shafts and standard Moog replacement ball joints.
Afco and ProForged make low friction extended upper ball joints. QA-1 has standard length low friction ball joints that can be serviced. -Al
"That'll never work....."
Old 01-15-2014, 08:34 AM   #5
J&S Racing
Liked 327 Times in 87 Posts
Afco steel bushings and there low friction ball joints, the Afco tops can be ordered .5 longer.
Old 01-15-2014, 09:41 AM   #6
FLEMING
Liked 55 Times in 26 Posts
I just did what J&S posted and it made my car totally different! It was an easy install, car has a ton of front end travel now and drives like a dream
FLEMING is offline   Reply With Quote
Old 01-18-2014, 09:42 AM   #7
mcashman
Liked 6 Times in 3 Posts
What is the point of the longer ball joints?
mcashman is offline   Reply With Quote
Old 01-18-2014, 10:16 AM   #8
Jim Cimarolli
Liked 166 Times in 46 Posts
They help to keep the camber from going off the radar at full lift.
Jim Cimarolli is offline   Reply With Quote
Old 01-18-2014, 10:31 AM   #9
Liked 1,912 Times in 429 Posts
The idea behind all of this is to reduce the friction, so that the front suspension moves freely, allowing the shocks to have complete control. It makes the front end motion very consistent and repeatable. The other part, as Jim said, is the longer upper ball joints keep the camber from making radical changes as the front end moves through its range of travel.
Another added bonus is increased front end travel. Combine this with the correct springs (which should lower the static ride height considerably, 1" to 2") and a set of shocks such as Santhuffs, and you have a front suspension that you can count on to allow the car to leave hard with the rear tires planted, yet remain easily controllable and driveable.
With offset upper control arm shafts for extra alignment adjustment, you can get the car to track straight consistently. They recently allowed aftermarket parts to reduce bump steer as well.
Find a shop that knows what they're doing, have the front end aligned with your weight in the driver's seat, you want no more than 1/8" toe in, 6 degrees or more positive caster, and zero degrees camber, at around 2" above static ride height, because you want the alignment as close to perfect as possible at the ride height the car has going done the track.
One thing I left out of this post, and a good racer reminded me of it, was that the Nova has less clearance than a Camaro, so you may not be able to run the exact caster and camber settings. You'll need to make the adjustments and then check carefully for clearance to make sure you do not create a tire clearance problem.
Old 01-18-2014, 08:52 PM   #10
J&S Racing
Name:	IMG_1534 (800x600).jpg
Name:	IMG_1535 (800x600).jpg
Did the install on mine today. Overall not that bad.
