Liked 99 Times in 49 Posts
1 set OF 2X3.5 SLIP ON COLLECTORS 1 Set tri Y 2X 3.5 COLLECTORS 80.00 each 1 Moroso vacuum pump new 275.00 set 041 heads angle milled 50 cc 250.00 set of cp ss pistons with pins 750.00 1 rossler lite weight 350 w/brake 3000.00 p/g input. 1 207 WA Lee q jet ss carb 450.00 1PRC 780 Stocker carb 800.00 1 402 375 stocker engine new 6000.00 sold car. a couple of 375 cams 50.00 a couple of sb ss cam std and 50mm 250.00for the 50mm. all plus shipping
Liked 2 Times in 2 Posts
JIm,
What is the part # on the Moroso Vacuum pump? Mike |
Liked 285 Times in 87 Posts
Jim...You have a PM. MB.
Liked 1,956 Times in 591 Posts
Jim,
I am interested in the turbo 350 you have for sale. If it is still available I would like some information about it. How old? Fresh or race ready? low gear ratio? what combo did you run it in? Thanks, Mike Pearson ssia2485@yahoo.com
Mike Pearson 2485 SS |
Liked 5 Times in 2 Posts
What 375 cams do you have? Larry
Which one do you want ? have 4or 5 of them. crane isky comp bullet.
Any of them 4 - 7 swap,s. What is the dur @ .050 & the lobe Seperation? Larry
No 4-7 swaps 260 270 108 106 mabye a 110
