Old 07-31-2013, 08:29 PM   #1
rod
Liked 20 Times in 15 Posts
Default tire section width?
if you had one tire, with 10" tread and mounted it on a 10" rim, and then mounted the same tire on an 8" rim...would the section width be wider on the 8" rim than on the 10" rim?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 07-31-2013, 08:52 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: tire section width?
It would appear to buldge, but I don't see how it would be wider.
I don't think you will see any gain doing that. My stuff has always been faster on wider wheels. Let us know what yours likes.
Ed Wright 4156 SS/JA
Old 07-31-2013, 09:07 PM   #3
magnumv8
when a tire manufacturer gives a "section" width dimension on a tire that is the measurement of the tire through the sidewalls on a "spec" size wheel...so the wheel width as it gets wider than that will actually make the section width dimension larger and the opposite on a narrower wheel....
D L Rambo STK 1300
magnumv8 is offline   Reply With Quote
Old 08-01-2013, 12:29 AM   #4
art leong
For my tiny tires (14 x 8 x 20) I have found (through multiple back to back to back tests) That a six inch wide wheel crosses the finish line 200 rpm's higher than an 8 inch wide wheel. It seems like the 8 inch wide wheel allows the tire to grow more.
Art Leong 2095 SS
Old 08-06-2013, 12:10 PM   #5
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Overall width of the tire would be more with a wider wheel.
So, to answer the question, I would say the section width would de-crease with the 8 inch wheels.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
