Old 07-02-2013, 10:46 AM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default s/st engine containment
Is the this mandantory to run in super street or optional.
astikhossw is offline   Reply With Quote
Old 07-02-2013, 08:48 PM   #2
Joe Pinkston
Joe Pinkston's Avatar
Default Re: s/st engine containment
A engine diaper is required for all S/ST cars. It does not have to be an SFI certified diaper but I assume one made by a recognised manufacturer. Universal fit diapers do the job and will run probably around $180. Contact Dennis from DRE and he can fix you up.
Hey Dan Moore, you're #1.
RIP Mark Graham & WB Hutto
Joe Pinkston 2155 S/ST
Joe Pinkston is offline   Reply With Quote
Old 07-02-2013, 09:52 PM   #3
JimL
Mandatory if you run over 135 mph and well worth it. If you ever have a blow up, you will be very glad you had one.
JimL is offline   Reply With Quote
Old 07-03-2013, 10:23 AM   #4
astikhossw
astikhossw's Avatar
Ok so the mandatory standard is over 135 mph.Thanks
Old 07-03-2013, 11:30 AM   #5
G E T Racin
straight from this years rule book sec 7 page 2
OIL-RETENTION DEVICE
All vehicles must utilize an NHRA-accepted lower engine oilretention
device; may use a belly pan in lieu of a device attached to
the engine. If belly pan is used, must extend from framerail to
framerail and extend forward of the harmonic balancer and
rearward to rear-engine plate and must incorporate a minimum 2-
inch-high lip on all sides. A nonflammable, oil-absorbent liner
mandatory inside of retention device. See General Regulations 1:8.
don't get confused with the gen regs. the above rule is specifically for sst. all vehicles need a diaper no matter what et's or mph they run.
Your div director or tech guys should be able to answer any questions you have.
Hope this helps
Gary T
G E T Racin is offline   Reply With Quote
Old 07-03-2013, 05:09 PM   #6
astikhossw
astikhossw's Avatar
I went and checked out the websight rule book after Jim wrote his comment and did not see the 135 mph rule ,but seems like i read it somewere that it was modified a little in superstreet but maybe i am mistaken.
