Old 06-27-2013, 12:32 AM   #1
gnicholson
Liked 4 Times in 3 Posts
Default electric throttle stop
i have a 4 hole dedenbear electric stop i've used for quite a while.my car isn't super powerful only running 136 mph in sst.my problem is occasionally the car spins coming off the stop and i also wonder if the stop slamming open causes fuel mixture issues.i wonder if an adjustable rate pneumatic stop would help cure these issues by slowing the opening and closing rate.it seems like it wouldnt be hard to make adjustable dampening device like a dashop for the electric stop
gnicholson is offline   Reply With Quote
Old 06-27-2013, 02:35 PM   #2
Chris Williams
Chris Williams's Avatar
Default Re: electric throttle stop
Go to the air stop, you won't regret it.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 06-27-2013, 05:00 PM   #3
Ron Finney
Ron Finney's Avatar
Are you coming off the stop in low gear?
Ron Finney 396V S/C
Ron Finney is offline   Reply With Quote
Old 06-27-2013, 08:38 PM   #4
gnicholson
no,shift on time.shift at 1 second right now.stop is set a .02 and goes off around 2.25
Old 06-28-2013, 11:47 AM   #5
Ron Finney
Ron Finney's Avatar
Other than switching to air (I don't care for either, but they do work) You might try raising the stop RPM so you aren't coing off with such a big throttle hit....although that will lengthen the time on the stop and may hurt mph a little. Some suspension tweaking might help as well to try to keep the rear tires loaded and stuck to the track.....
Ron Finney 396V S/C
Old 07-08-2013, 02:19 PM   #6
Michael Pliska
I've been daydreaming about doing this for a while. When I was doing engine development for a forklift manufacturer we used dashpots as an "idle up actuator" to mechanically kick up the idle in response to a loss of vacuum. Somewhere I still have some of those prototype dashpots, I've thought about using them with a needle valve regulating the flow out of it.
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
Old 07-10-2013, 06:17 PM   #7
gnicholson
allmost exactly what i was thinking.i like the reliability and no hastle of electric
