Old 06-23-2013, 04:34 PM   #1
Lonnie Cox
Default Cranking compression reading
76 camaro I/SA 350 40 over, cp pistons, Bullet cam, any idea what cranking compression we should have. Just would like to know.cam is in at 98
Thank You
Lonnie Cox is offline   Reply With Quote
Old 06-23-2013, 05:38 PM   #2
GTX JOHN
Liked 2,518 Times in 702 Posts
Default Re: Cranking compression reading
MY 9.5 to one Mopar Small Blocks run approximately 160 lbs.
Old 06-23-2013, 05:48 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Lonnie,
The numbers may not tell you very much when you are looking for a "high" value. The compression test is a good way to tell if any one (or a number of) cylinders is having a mechanical problem. What you look for is a pattern where each of the cylinders is within 5 to 10 psi of the others.
It has been my experience that a "leak-down test" is a much better gauge of engine health and efficiency when done properly. The kit is not that expensive and only requires an air-compressor capable of 100 psi of pressure. Done on a regular basis, it is a much more accurate diagnostic tool.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
