Old 01-15-2007, 07:50 PM   #1
Brian Holcombe
Default 385" SBC, PUMP GAS engine, Street/strip 11.15@117
For Sale:
Street/strip Pump gas
4.040" 4 bolt 010 casting block 3.75? Stroke crank= 385ci
The block was prepped by Windsor Automotive Machine (Paul Rock)
- The block prep included being decked to 9.03"
- Line honed mains, Bores honed with a deck plate
-SRP Forged Pistons #138094 with Plasma Moly file fit rings
-9.85:1 CR Completely pump gas capable
-Clevite 77 bearings
-Fel-Pro Gaskets
-Eagle Cask Crank 3.75" Stroke External balanced by Performance machine
-Crower Sportsman 6? cap screw Rods
- All bolts internal and external are ARP, with exception to the rod bolts which are Crower.
-Milodon louvered Windage tray, and Milodon oil pan (Stock style)
-Melling Standard oil pump, Heavy casting design with pickup epoxied and staked.
-Cloyes true Roller timing set
-World Products Sportsman II 200cc intake port heads 72cc combustion chambers fitted with Race Flo 2.02/1.60 valves bowl blend
All the valves (brand new) were resurfaced, and back cut.
Head work included a bowl blend and 3-angle (3 seat angles and a back cut) competition style valve job
-Performer RPM intake manifold
-Crower Cams #00321 (Ground on a 108LSA) Solid Flat tappet 242/248 Dur .050? .482/.504" valve lift Crane double Valve Springs #99893-16
-Rocker Arms- Crower Stainless Steel 1.5
-Comp One Piece .080? wall 5/16? Pushrods
-Headers- 1-5/8? primary 3? collector, 33? average primary tube length
Scavenger style collector
-Steel damper
This engine has 96 1/4 mile passes on it, and less then 3000 street miles.
It has gone 11.15 at 117.5 MPH in a 3210lbs 67' Camaro.
Comes complete, less distributor, waterpump, alternator and carb. (carb is negotiable).
$4,800
Interested in Stacks of Paper ONLY, no trades.
Hear it run prior to purchase.
[image]http://i27.photobucket.com/albums/c181/SpeedyGoomba/P1010035.jpg[/image]
Brian Holcombe is offline   Reply With Quote
Old 01-16-2007, 08:48 PM   #2
Brian Holcombe
Default
perfect engine for a street/strip ride, street rod, or drag car!
Old 01-17-2007, 01:35 PM   #3
SC1448
Liked 2 Times in 2 Posts
Default
Location?
Thanks!
-Don
SC1448 is offline   Reply With Quote
Old 01-17-2007, 07:30 PM   #4
Brian Holcombe
Default
I'm in Hamilton NJ,
My contact is 609-462-6958
Old 01-17-2007, 09:33 PM   #5
TheGoodBadGuy
Default
I can speak first hand for this piece....it's EXCELLENT!. A great engine for any hotrod to cruise around with and deadly at the track. I drove it a couple of times, it's the real deal.
You cannot bulid it for less than 6000.00.
Adam
Adam Landolfi
www.LandysPerformance
732 462 0911
www.LandysPerformance.com. Established in 1968 by \"Coney Island Ralph\" Landolfi, my Dad, we have the experience and the compassion to help any racer with any questions.
Drag Racing is an addiction second to none. Furthermore, if you get on the Racing Train at the wrong stop, well, every stop after that is the wrong stop.
If we can help, feel free to let us know right here.
Adam Landolfi
www.IWantThatMusclecar.com
732 462 0911
732 995 2070
TheGoodBadGuy is offline   Reply With Quote
Old 01-18-2007, 03:23 PM   #6
Brian Holcombe
Default
thanks Ad!
I want to add, that the stainless exhaust system, dynomax ultraflow mufflers and Meziere water pump (55gpm!) are being added to the deal.
If interested, act quick, i'm giving it two weeks then stashing it in my garage and not enteraining any offers short of $5000.
Old 01-20-2007, 05:19 PM   #7
Brian Holcombe
Default
lowered the price to $4000 for those interested.
Old 01-20-2007, 08:11 PM   #8
Smink
Default
Add the carb & dist? I'll take it........
Smink is offline   Reply With Quote
Old 01-20-2007, 08:39 PM   #9
Brian Holcombe
Default
Smink i'm using the carb/dist on the next engine. $3900, without the carb or dist.
