Old 03-31-2013, 10:58 AM   #1
js72mav
Default propotioning valve ?
Does the adjustable proportioning valve go before or after the line lock solenoid? And why? just trying to understand.... thanks!
js72mav is offline   Reply With Quote
Old 03-31-2013, 03:29 PM   #2
Todd Hoven
Guest
Posts: n/a
Default Re: propotioning valve ?
I have a question to add to this? On a car with aftermarket racing discs on the front and drums on the back, what line do you install it on? Front or rear
Old 03-31-2013, 03:43 PM   #3
Ed Wright
Ed Wright's Avatar
Rear, which also answers the previous question.
Ed Wright 4156 SS/JA
Old 03-31-2013, 04:01 PM   #4
js72mav
Now I am even more confused than before. Strange says that in drag cars it is usually in the front and street cars on the rear line.
Todd that is the same set up I have, discs in the front and drums on back.
Old 03-31-2013, 04:56 PM   #5
Todd Hoven
Guest
Posts: n/a
Same here Jamie. I bought new Strange front brakes and they told me to install it on the front. Willwood says to run it on the rear. My car had Willwoods on the front and it always seemed to have to much front brake bias. Strange also told me to run a 2 pound residual valve for the rear brake line.
Old 03-31-2013, 05:25 PM   #6
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
something to try before you install the proportioning valve ,, if you have access to pressure gauges for brakes ,put one the front ,one on the back apply pedal pressure and read gauges ,,if its higher on the rear install on the rear ,,higher on the front maybe you don't need one or install on the front ,, my calipers are the same size on front and rear ,I put mine on the rear line gmonde
Old 03-31-2013, 06:03 PM   #7
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Dave Noll, EF/S ,?/SA 6526
Old 03-31-2013, 04:20 PM   #8
mike britt
Liked 66 Times in 31 Posts
Put mine on the rear and have the valve all the way open. Should of left it on the shelf.
mike britt is offline   Reply With Quote
Old 03-31-2013, 05:49 PM   #9
1720
1720's Avatar
Liked 2 Times in 1 Post
Same here! Rear wide open.
RT - SS/X circa 1972.
Talbot Racing Family
1720 is offline   Reply With Quote
Old 08-19-2013, 05:03 AM   #10
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Originally Posted by 1720 View Post
same here! Rear wide open.
x3
