Has or is anyone using the Reactor Flexplate? Is there any performance advantage?
Thanks Scott Tilley IHRA SS/PDAII |
Liked 21 Times in 9 Posts
Scott we tried it years ago on a small block comp dragster and did not
see a benefit with it. Maybe someone else had success with it. |
Liked 333 Times in 180 Posts
THEY WORK!!!---almost the same weight as a SFI stamped steel flexplate,machined not stamped out truer tolerances overall , not prone to cracking in the crank bolt area,replaceable starter ring gear, can run a smaller flexplate(dia), keeps the engine up on the RPM not as much drop off, can run a smaller bolt circle on the torque converter less weight there, can use a smaller dia torque convertor--- other than that no advantages over a stamped steel flexplate---FED387
Liked 885 Times in 238 Posts
Any one try the CSR aluminum flex plate ?
They are similar to the Reactor and are supposed to weigh only 5 1/2 lb. I'm thinking about either one for a B/ND I'm working on.
Liked 3 Times in 1 Post
Several styles of Reactor Flexplates available. Do your homework......
Wade |
