Liked 135 Times in 74 Posts
Towing with a 1998 motorhome, has 7.4l chevy towing a 28ft champion trailer. When cruising at 65 mph on flat ground all is well, as soon as we hit grade, vibration starts, feels like the converter cannot decide to unlock or trans wants to downshift. If I depress gas pedal to full throttle it will downshift and vibration stops, then it seams to upshift but not lock up converter, when back to level ground converter locks up and all is well. no other trans issues. Motorhome has 58,000 miles.
Been researching options, 1 is to upgrade converter to TCI/hughes/B&M 2 is to rebuild trans. 3 Fast has a tuner / transmission re calibration programmer that will change transmission settings. also thinking off upgrading exhaust for a little more horsepower and torque. If all of the above is necessary, then may be time to upgrade motorhome to newer model or diesel. Any recommendations ? |
Liked 240 Times in 112 Posts
I saw a local shop sell a customer a trans rebuild for the same issue your having. When the customer got it back it, did the same thing. In his case the engine was missing under load. Common issue's would be carbon tracked plug, plug boot, weak injector if it has 8, coil output if it has 8, or plug wire etc.
Dave Noll, EF/S ,?/SA 6526 |
Liked 1,898 Times in 426 Posts
Make sure it does not have an engine miss.
In the event that it does not have an engine miss, have it rebuilt by a shop that has someone who has full knowledge of all of the fixes that Sonnax has for that transmission, and will install them correctly. Have the converter rebuilt by ACI in Old Hickory TN, just outside of Nashville.
Alan Roehrich 212A G/S |
Liked 216 Times in 77 Posts
Put a fuel pressure gauge on it and make sure it holds pressure after its shut off. If it does not pull the upper intake so you can get to the vacuum line going to the fuel pressure regulator and the injectors. Disconnect the vacuum line from the fuel presure regulator and cycle the key so the pump runs and builds pressure in the sytem. If fuel comes out the vacuum port the regulator is bad. If no fuel comes out take the injectors loose and see which one leaks fuel with pressure on the system. My bet is Cyl #4 injector is leaking maybe others too. No idea why but of the several I have done #4 leaks everytime. The regulator and injectors are about 80 bucks a piece at napa. If the regulator is leaking after you replace it recheck and make sure it cured it and there is not one or more injectors leaking before you reinstall the upper intake. Also replace the small vacuum hose with a new piece of hose if the reglator was bad.
If all is well here and its holding pressure take a good look at your engine mounts. If it has a bad one and they are like the pickups let me know. And I will pray for you. They are a SOB to change. Hope this helps |
Going to put new plugs wires and cap on. Injectors were checked last year by a fellow drag racer and they were okay. will check regulator.
Thanks for info. I will follow up when work is complete. |
Just curious if you got your Motorhome fixed yet ?
